Question about Camping, Backpacking & Hiking
How to change a battery in a lsi nite tracker rc3800
Day light and nite headlights
You should be able to adjust them manually on the dash .
Aug 03, 2014 | 2003 Chevrolet Tracker
Remove front drive shaft 1994 tracker
ok ,it's not hard, but if you let the front yoke fall out, you get 2 eat
3 quarts of Transfer case oil. in the face. (the forget to warn of that)
the yoke is splined and will fall right out, if not careful.
undo the 4 ujoint nutbolts. (1 easy step)
or read the FSM see PDF page 26 (actual 24) the 3 steps.
under new 4sp filter.
http://www.acksfaq.com/96-FSM-v1-7A-pdf.htm
or more here
http://www.fixkick.com/
see the 4 holes here?
http://www.fixkick.com/tranny/clutch/engine-rear1.jpg
unbolt it and carefully tie it UP (prop shaft), and with a hard rear bias.
Id use bunji cords.
May 17, 2014 | Geo Tracker Cars & Trucks
Dc 30 tracker collar keeps shutting down, I have changed battery and recharged unit and it still only runs for about 1 min.
3 PointsProblem with Cars & Trucks
Dc 30 tracker collar keeps shutting down, I havecars and trucks,my car has no tracker., does yours, ,omg
Oct 12, 2013 | Cars & Trucks
I have a fairly new battery, but something is draining the battery over nite
L'm sure its your alternator ! he did not give the correct voltage and not charge appropriately your new batterie , just check it and you will see ! :)
Apr 19, 2012 | 2002 Ford Taurus
Battery size for a 2003 chevy tracker
Here is the information on the battery size from NAPA. The CA(cranking amps) and CCA(cold cranking amps) can be changed within a certain amount but the dementions should stay the same as well as it being a top post battery.
Battery CA @ 32 Degrees F : 780
Battery CCA @ 0 Degrees F : 625
Battery Height : 8"
Battery Length : 9 1/16"
Battery Load Test Amps : 312.5
Battery Posts Type : Top Mount
Battery Reserve Capacity : 95
Battery Voltage : 12
Battery Weight : 32.5
Battery Width : 6 13/16"
Nov 16, 2010 | 2003 Chevrolet Tracker
91 Geo tracker , Starting problems
my geo tracker wont turn over the lights wont come on nothing is working iv tested the battrey its fine and checked all the fueses they are fine too why is there no power to any thing?
May 31, 2010 | 1991 Geo Tracker
Rear Brake Proportioning Valve
did you ask GM (trackers are GM) not all parts are same GM tracker to sidekicks ( i can name many)
suzuki sells it. and try car-parts.com for wrecker used sources.
used brakes , hummmmmm
96 is a major year, change, so watch out of wrong answers.
there are 2 valve, 2door and 4
suz pn is.
4 = 51930-56B20
2 = 51930-60A40
dont by the wrong one, or danger awaits you. and thin wallet.
1 of 2 valves here.
http://www.oemsuzukiparts.com/parts/index.cfm?make=Suzuki&year=&searchText=51930-56B20&action=oePartSearch&siteid=214330
Nov 14, 2008 | 1996 Geo Tracker 2 Door
Camping, Backpacking & Hiking Logo
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
