Will not turn on and makes a hissing sound and shuts off
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
This is not the problem with the remote control. Contact any service technician, and check the TV. It is faulty. If you're sound in electronics, and if you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 22, 2013
What makes my 2001 chevy silverado airconditioning make a hissing sound when my air is on
Check the bearing in the end of the blower motor. They go bad and make a noise and over time will start rubbing and squealing like crazy.
Jun 12, 2017 | AC Cars & Trucks
Air noise coming from under bonnet audi a8 d2
Sound is completely normal on all Audi's.
Your A8 uses an Orifice tube to regulate the pressure between the two halves of your air conditioning system. A hissing sound is normal after a shut down as the system equalises. Usually lasts about a minute and is more noticeable on warmer days.
Location on an A8 is on the very right hand side of the bonnet just under the windscreen - that's where the hissing will be coming from.
Apr 17, 2013 | Cars & Trucks
Hissing sound after flushing a flushmate
The washer that shuts the water off is failing. It shut stop incoming water completely when the tank is full.
Jan 11, 2013 | Sloan M-101526-F Flushmate?® Complete...
2001 Honda CRV makes a hissing sound (HISS HISS HISS HISS ) when makins a sharp left turn while going down a hill at about 30 MPH. The sound continues for about a mile after comming out of the turn a
sounds to me like something is rubbing on the tire. best bet would be to put the vehicle on stands and have a buddy turn the wheel back and forth while you watch from underneath. hope this helps
Mar 12, 2012 | Honda CRV Cars & Trucks
It make a hissing sound and then it shuts off
open the hood up and look for a missing vacuum port plug on the engine intake manifold, sounds like the case here, that would cause a really loud hissing noise.
Sep 16, 2009 | 1996 Buick Skylark
Fuel pressure regulator makes hissing sound
your fuel pump should cycle on until the proper fuel pressure is achieved then it should shut off
Jan 25, 2009 | 1997 Volkswagen Golf
Monitor won't turn on.
Does the cord plug directly from the wall into the monitor, or is there a power "brick" adapter between?
If there's a "brick" listen to see if the hissing is coming from the monitor itself or the brick. If the hissing is coming from the brick you may just need a new power adapter.
If there's no brick or the hissing is coming from the monitor, the monitor probably needs repair. With the price of LCD monitors these days compared to the price of labor, you're probably better off getting a new LCD monitor. Just make sure you take your old one to a proper E-Waste facility so it doesn't pollute the environment.
Apr 05, 2008 | Gateway FPD1760 17" LCD Monitor
Hissing Sound
A hissing sound that comes from the back of the set (not from the speaker) usually indicates a high voltage leak, most likely around the "suction cup" at the top of the picture tube or around the flyback transformer. Remove the back of the set and turn it on, and when you hear the hissing sound, shut off all the lights in the room and you should be able to see a purple-ish or white-ish glow from the spot that is hissing. Shut the set off, discharge the high voltage and clean and seal the problem area. Of course this should be done by someone experienced with stopping high voltage leaks.
Jun 22, 2007 | Durabrand DU1901 TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
