Question about Garden
Have an 8360 RT Tractor shuts down , steering control and chassis control warning can not move it- all electrical dies- have spent numerous service calls- getting worse- been used maybe 10 hours since May- sets idle most of the time- has everyone baffled to what is going on- has about 400 hours and is 2 yrs old-
leorcid
  • 281 Answers
SOURCE: noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Posted on Feb 06, 2008
  • 211 Answers
SOURCE: idle is off??
hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Posted on Dec 31, 2008
jerryg50
  • 1667 Answers
SOURCE: Vizio shuts itself off
There may be some components failing in the power supply or one of the circuit boards that are causing too high a current pull.
I realize that this answer is very vague. Without doing proper diagnostics, it is impossible to guess at something like this.
Out of warranty repairs on these sets can be very expensive. I would suggest that if the set is going to be expensive to service, it would be best to replace it with a known brand name that offers an extended warranty with local service. You will pay more, but you will have dependability and better quality.
Jerry G.
Posted on Jan 02, 2009
SOURCE: 20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
Posted on May 06, 2009
Power steering failure
I would have the power steering system tested, it is a possible steering rack issue.
Jun 02, 2017 | Volkswagen Cars & Trucks
=1995 volvo road tractor symptom [engine shuts down] code; active,engin e, intake,air,tmp,short,+v
I recently came across a similar situation in a isuzu that took some time to diagnose. What if eventually turned out to be one injector had an intermittent failure and it too out 2 other injectors and the engine shut down. If the vehicle sat for 1/2 hour it restarted and ran again for sometimes days before the fault again appeared. It was tracked down by running the truck on a chassis dyno under load and when the fault appeared each injector was disconnected until the faulty one was revealed. If these symptoms parallel yours I suggest you point the mechanic in that direction .
Mar 11, 2013 | Cars & Trucks
Windows keeps shutting down unexpectedly
Your computer is overheating, it is shutting itself down to prevent damage to the internal components.
Your computer should be serviced by a computer technician. He/she will clean the components and chassis of dust. This will increase airflow over the components, meaning your system will be stable and will not shut down unexpectedly.
Take care!
damnor01
Apr 28, 2012 | Microsoft Computers & Internet
I have a HP Compaq DX2000MT computer. When I want to start up the pc, he gives 10 beeps and the following message : Chassis fan not functioning, check fan connections & call for service. Shutting...
Without the chassis fan the pc would overheat and fry so it's shut down. Do what the warning message says: open the case, clean the interior and check the wire connector of the fan. If the fan still doesn't turns then it has failed and it will have to be replaced - a new one costs$10 at every pc shop.
You will need the manuals for service and maintenance
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=12454&prodSeriesId=401819
Aug 07, 2011 | HP Compaq dx2000 Microtower PC Desktop
Husqvarna tractor starts fine but when I let the pedal out to go the tractor shuts off immediatly. Whats going on?
It sounds like you may have a bad seat switch. There is an electrical switch under the seat that senses when there is weight on the seat, if no weight (or person) the switch keeps the tractor from moving. With the engine off, lift the seat and find the wires going to the switch. Pull the connector off the switch. Put a jumper (short piece of electrical wire about the same diameter as whats in there now) into the connector (one end in one side of the connector, one end in the other, make sure it touches the existing metal on the end of the tractor wires) Put the seat down (make sure that the jumper wire does not touch anything metal under the seat when you put it down) sit on the seat and start the engine. Try driving it. If it moves, the switch was bad. If not let me know.
Dec 22, 2010 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I need a diagram on how to remove a heater core in a 1994 mercury villager
big job. entire heater plenum has to come out. 6 hour job.
http://groups.yahoo.com/group/villagerquest/
Instrument Panel Removal
  1. stv~us~en~file=ani_caut.gif~gen~ref.gif WARNING: THE BACKUP POWER SUPPLY ENERGY MUST BE DEPLETED BEFORE ANY AIR BAG COMPONENT SERVICE IS PERFORMED. TO DEPLETE THE BACKUP POWER SUPPLY ENERGY, DISCONNECT THE BATTERY GROUND CABLE AND WAIT 10 MINUTES.
    Disconnect the battery ground cable (14301).
  1. Remove the access cover from the bottom of the steering wheel (3600) and disconnect the driver side air bag module electrical connector.
  1. Open the glove compartment, then pull the access panel from the top of the glove compartment. Disconnect the passenger side air bag module electrical connector.
  1. Remove the four console compartment plastic screws or C/D changer cover plastic screws (if equipped) and the console compartment door (045G36) or C/D changer cover.
  1. Remove the two LH inner instrument panel lower cover screws and the plastic nut.
  1. Remove LH inner instrument panel lower cover (044L97) and disconnect the foot lamp electrical connector.
  1. Remove the two RH inner instrument panel lower cover screws and the plastic nut.
  1. Remove RH inner instrument panel lower cover (045G22) and disconnect the foot lamp electrical connector.
  1. Remove the plastic screw, two lower screws, two center bolts, two upper screws and the screw at the instrument panel bracket, then separate the glove compartment from the instrument panel (04320). Disconnect the glove compartment striker plate catch electrical connector.
  1. Remove the two instrument panel to passenger side air bag module bracket bolts.
  1. Remove the four passenger side air bag module nuts and the passenger side air bag.
  1. Remove the RH instrument panel screw.
  1. Remove the four C/D changer screws.
  1. Remove the C/D changer and disconnect the C/D changer electrical connector.
  1. Remove the instrument panel ash receptacle (04810).
  1. Remove the two upper center instrument panel finish panel screws and the two lower center instrument panel finish panel screws.
  1. Remove the center instrument panel finish panel and disconnect the cigar lighter socket and the cigar lighter illumination lamp electrical connectors.
  1. Remove the two instrument panel ash receptacle bracket screws and the instrument panel ash receptacle bracket. Disconnect the instrument panel ash receptacle lamp electrical connector.
  1. Carefully pry the center A/C register from the instrument panel.
  1. Remove the hose from the ambient temperature sensor and disconnect the ambient temperature sensor electrical connector (if equipped).
  1. stv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result. Refer to Module Service Procedures in Section 18-01 .
    Remove the four radio chassis bracket screws and pull the radio chassis (18806) and climate control assembly from the instrument panel.
  1. Disconnect the three radio chassis electrical connectors, the antenna lead, the three climate control electrical connectors and remove the radio chassis and climate control assembly.
  1. Remove the plastic screw, the two instrument panel steering column cover screws and the instrument panel steering column cover (04459).
  1. Remove the four LH instrument panel reinforcement bolts and the LH instrument panel reinforcement. Disconnect the diagnostic electrical connector.
    Remove the instrument cluster (10849). Refer to Section 13-01A (electronic cluster) or Section 13-01B (conventional cluster) for the removal procedure.
  1. Disconnect the seat belt warning chime electrical connector. Remove the two seat belt warning chime screws and the seat belt warning chime.
  1. Remove the four steering column nuts and lower the steering column assembly.
  1. Remove the two LH instrument panel screws.
  1. Remove the center instrument panel screw.
  1. Remove the LH inner duct screw and the LH inner duct.
  1. Disconnect the power outside rear view mirror control switch electrical connector.
  1. Pull off the upper portion of the LH inner door opening weatherstrip. Remove the windshield side garnish moulding (03598).
  1. Pull off the upper portion of the RH inner door opening weatherstrip. Remove the windshield side garnish moulding.
  1. Remove the instrument panel upper moulding (04268) and disconnect the sun sensor electrical connector (if equipped).
  1. Remove the light sensor amplifier from the top right side of the instrument panel and disconnect both light sensor amplifier upper and lower electrical connectors (if equipped).
  1. Remove the instrument panel center nut.
  1. Remove the two instrument panel upper bolts.
  1. Remove the instrument panel from the vehicle.
May 20, 2010 | 1994 Mercury Villager
Service variable effort steering warning is coming on.what do i do to service it? 2004 gtp
i have an ABS, Traction Control, and Variable Steering warning lights come on right after i put the car in drive and move forward.
2005 Pontiac Grand Prix
Aug 15, 2009 | 2004 Pontiac Grand Prix
When i engage the blades the tractor dies.the tractor is only a month old.
Do you have a service warranty?? If so I would call them and have them go through it. If not there is a switch under the seat that may be bad. It shuts the tractor down when the blades engage and there is noone on the seat. Check that and let me know..
Jul 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Electrical sytem? inconsistently shuts car down
These engines have a sensor known as the Crankshaft position sensor, they are most of the time the part that causes these problems, it is located on the front of the engine, it gets it's signal from the crank pulley/harmonic balancer, if it goes open when hot the engine dies, when the sensor cools back down the eng will restart.
Oct 10, 2008 | 1994 Pontiac Grand Prix
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
