Question about Orbit 3/4-in Brass Electric Anti-Siphon Irrigation Valve 57065
My Orbit brass sprinkle will not shut off the water flow to the sprinklers. I took it apart. The plunger is free, the magnet controller is working and I have a steady flow of water to the controller. Is there an o-ring or a needle valve I may have lost in the process... The spring that piston back down on top of the inlet water port doesn't seem strong enough to stop water flow of 50 to 60 pounds water pressure.
  • 50 Answers
SOURCE: Solenoid on one station, sprinklers on another, cant turn both on
the should be a pump or master solenoid connection inside the controller
Posted on Apr 13, 2009
  • 1723 Answers
SOURCE: Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Posted on Jul 02, 2009
SOURCE: I have an Orbit WaterMaster Sprinkler control, it
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
Posted on Jun 23, 2010
SOURCE: I have a Orbit 57161
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Posted on Oct 06, 2010
SOURCE: My orbit tractor lawn sprinkler
try turning the nozzles the other way - they should turn counter clockwise when looking from the top, not clockwise.
Posted on Aug 18, 2011
Imperial valet timer
Big box stores and sprinkler supply stores.
Aug 22, 2014 | ORBIT UNDERGROUND Sprinkl pop-up 4 adj"
Orbit sprinkler manuals
Check for obstructions in the mechanism. Follow the instructions on the adjustments.
Aug 09, 2014 | Orbit Irrigation 58308 Tripod with Brass...
Can this valve be repaired?
Check to see if the company has a rebuild kit for the unit.
Jun 06, 2014 | Orbit 51016 3/4" Brass Anti-Siphon Valve
Just hooked up (water lines only, no control wiring yet) a 3 station Jar top Manifold. One of the valves is open while the other two are shut. Have taken apart and see not apparent reason for it to be...
Make sure the bleeder is closed or solenoid is tight. Sometimes valves just fail without a obvious reason. Suggest purchasing the same jar top valve and rebuilt it using the new diaphragm, spring, bonnet and solenoid. This should correct the problem.
Apr 13, 2014 | orbit"" 1"" jar top valve"
Orbit sprinkle model 57894
Copy following link for sprinkler and irrigation timer manuals from all companies:
Add a comment and describe problem in detail
Jun 29, 2013 | Hardware & Accessories
One of my zones keeps sprinkling after I shut the timer off
Which timer do you have?
Copy following link for sprinkler timer manuals
Add comment and describe timer in detail
Apr 20, 2013 | Orbit Sprinkler System Power Source...
My hunter SRC lawn sprinkler controller sprinkles t
First thing to check is the power supply. Are the batteries fresh? Most likely you need to reprogram. There is likely a previous program that is causing the errant watering. Here is a good video on how to program.
Oct 22, 2011 | Nelson Sprinkler: Traveling Tractor
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Sticking impulse sprinkler
wd 40 is the worst thing, oil based prod break down internal parts. best is to dig up take apart wash with water and reassymble. if not better only choice s to buy new
Jun 27, 2009 | Orbit Sprinkler System Power Source...
Orbit 3/4-in Brass Electric Anti-Siphon Irrigation Valve 57065 Logo
44 people viewed this question
Top Orbit Garden Experts
Are you an Orbit Garden Expert? Answer questions, earn points and help others
