Question about E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop
Computer not running quite right
I turn on my comp and everything powers up but i cannot here my hard drive running and my comp screen says there is no input signal so i thought it might be my motherboard so i bought a new one and new cpu but this didnt seem to work either i almost to the point of pulling my hair out any help on this matter would be great!
  • pistolchick Jul 10, 2008
    That also happened to me and I still have no solution. I tried different outlets, rooms and even took it to my sister's house and still the same problem. Bought a new CPU, but it's a pos and so slow in comparison that I think I can actually see my fingernails growing waiting for a page to load. So frustrating because I'm not ready to give up on my hp, i love it. What to do?? ;<
  • 781 Answers
Enter BIOS settings set back to default see if that works
Posted on Jul 19, 2008
Hey ********!! If they took the time to write here, don't you think they may have tried the obvious?? Try adding something constructive next time!
Posted on Apr 06, 2008
    Problem Solver:
  • 12 Answers
Try connecting the main power cord to the diffenrent wall outlet...
Posted on Sep 28, 2007
SOURCE:
When running test on my Dell Vostro 1500, error code 0146 shows
Error 0146 is a failed hard drive or bad drive sector, you have a bad hard drive,
Mar 04, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
I have a 4GB which i used to transfer quickbooks from comp to comp. It worked for a few months, then quit
the usb stick has most likely failed. if the computer will see it in the my computer screen, see if you can format it.
I have lost several sticks over the years that the computer will no longer see.
Nov 07, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
GT5034 has power, blue light on power button, no beep, no boot, sounds like fan running hard. Hard drive light is on for a while and both CD drives green lights flicker. Nothing comes up on the monitor. HD...
powersource is good.motherboard might be the problem.harddrive can be tested by putting it in
another computer and see if it boot up.to test the mother board unhook the cd drives and harddrive.turn
on the computer and see if the gateway logo comes on.if it still does the the samething with everything unhooked
then it might be the bios.you might have to flash the bios and reinstall it.to do this i recommend you take it to a
shop.if the comp runs with everything still unpluged and stops then you know that you have a wrong
setting on the harddrive or cd drive.if you got two of anything make sure that you have a slave or master.if you nned me to
write a guide email me at [email protected] or if you got anymore questions.
Jun 29, 2009 | Gateway GT5034 PC Desktop
Hardrive won't run, screen is black
Most possible one of your Toshiba Tecra m4 driver is not working properly, but don't worry give me a call at +1 (833) 493-0111 so that i can suggest you the right way to fix it!
Apr 13, 2017 | Toshiba Tecra M4-S435 Tablet PC
SOLID AMBER LIGHT ON DIMENSION 3000
One of two things:
Either the power supply is marginal
or
the motherboard is bad.
Good luck.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Can you turn the hard drive of at night when not in use and not loose any data?
I would recommend you put your PC on standby that way it shuts off your computer but of course once you move the mouse it wakes up again. Or you can choose to hibernate so it saves everything your doing to your hard drive and once you turn your PC on it will restore everything you were doing from the hard drive. But putting your PC on stand by you shouldn't lose any work.
Jul 09, 2008 | Computers & Internet
Compaq presario evo 1015v
sounds like a bad screen this might be able to be remedied by hooking the laptop straight to a computer monitor threw the ports provided in the back
also you could have bumped something loose inside like a video card if any cards or memmory comes loose this will give you black screen of death the laptop will have to opened and cards pressed down gently
theres the solution of your power supply on the laptop went out and you need a replacement
if power supply went out it doesnt hurt your comp it just makes it hard to run
May 21, 2008 | Compaq Presario 900 /1500 Series EVO...
Compaq presario 5000 not booting up right.
Does the Compaq logo appear when you try to start the computer? Try pressing F10 several times after turning on the power. This should start the "recovery console", which will give you some options for restoring Windows. If the recovery console doesn't start up, there is a good possibility that your hard drive or power supply module may be defective. In that case, you will probably need professional assistance to diagnose the problem.
Mar 19, 2008 | Compaq Presario 5000 PC Desktop
She won't run
do you still have your restore CD? try to fresh restore it and updates everything on that unit again. Often online gamers send you malicious script that crashes your system.
Aug 04, 2007 | Gateway GT4022 PC Desktop
E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz / 512MB DDR / 160GB HDD / DVDRW DL / nVIDIA GeForce 6100 I... (RBC6423) PC Desktop Logo
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
