Question about Mainstays Hampton Gazebo, 118" x 118"
Hi I recently purchased a mainstay gazebo and the plastic parts that hold the bars together cracked and broke.....Now I am at a total lose as to how to put it up again....please help me .... I really enjoyed it even if it was for such a short time.....not sure if they were just flimsy from the get go or actually not sure what happened....not sure what to do with it....don't have a receipt because didnt' expect nor thought of ever having to return it...please help me...thank you! Barbara :(
Need parts for my grayson gazebo. the middle bar that has the eight legs,it was bent and broke and now I can't put it up and I just bought it so I was told to contact Bondsmfg
If you owned it for 30 to 90 days or less, take it back to the store to get another one. Bring your receipt, the item, box and all shipping material, back to the store too. Call the store to see what the actual time frame is to be able to bring it back for exchange or refund.
Aug 30, 2015 | Garden
User manual mainstay grill gazebo
Know make and model, call or contact manufacturer directly, they actually prefer that you do!, they will be glad to forward you instructions.
I've purchased a few items with missing pieces, and all are our were eager to get me what I needed! No charge!
Sep 27, 2014 | Garden
I need instructions for putting together the garden oasis bay window gazebo please purchased 8/10/13 from sears
Contact manufacturer, they can help.
They do prefer you contact them, over from where you purchased.
Aug 03, 2014 | Garden Oasis Bay Window Gazebo Brown 10...
I am looking for instructions for Mainstays crossman gazebo size 176x114.
i need the instruccion sheet for 6x3 mainstays
Aug 17, 2011 | Garden
Just recently my car door wont open from the inside, what might the problem be?
prob, the plastic clip holding the bar to the handle inside has broke very common. you can buy these at any parts store for about 5.00
Aug 01, 2011 | 1999 Mercury Cougar
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
Drivers side tail light
Remove the tail light, then the grey bar with all the lights by removing the two screws at the top and bottom. play with the light socket that dosen't work and chances are that it is cracked and broken. If it is broken then the contacts within are not making contacts becuase the black plastic socket is used to hold the contacts together. If you are handy, you can tear open the grey bar and solder the contacts together, then epoxy the bar back together. Or, find, purchase and replace the grey light socket bar.
Oct 26, 2009 | 2002 Chevrolet TrailBlazer
I am furious!! My
fibre glass matting to repair it
Jun 30, 2008 | 1986 Volkswagen Wagon Camper
Mainstays Hampton Gazebo, 118" x 118" Logo
67 people viewed this question
Top Mainstays Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Mainstays Garden Expert? Answer questions, earn points and help others
