Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
My G.E. refrig model ps123mgrc will not despense
My G.E. refrig model ps123mgrc will not despense ice or water
buddymcl777
  • 67 Answers
SOURCE: water just keeps pouring out of the top of the ice despenser
I would say your water valve in the freezer is locked in the open postion or has broken.
Posted on Jun 07, 2009
SOURCE: My GE GSS25VFPAWW side by side refrig. wil not despense water.
I turned off the unit for an hour with the door open and the ciller tubes thawed. the water started wotking again.
Posted on Dec 27, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile Refrig model PSC23SGRC ice maker
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Posted on Jan 20, 2010
  • 1891 Answers
SOURCE: GE Refrig. Water leaking on floor after ice maker stopped
look at water delivery tube to the ice mker . it has iced over and pluged up causing the water to go out the back and down on floor . . clear the water tube with hot water and problem is over . .. some models cah use a updated water tube. mm
Posted on Jul 16, 2010
aasc
  • 1606 Answers
SOURCE: Ice/Water despenser Problem- not working(no lights on the button)
Replace the main control board . Pt # WR55X10942 is the part number . The dispenser board has lost communication with the main board . The main control board is behind the refrig , behind the small 8X10 inch panel . There are 6-8 group plugs which will only fit in perspective plugins , so this board is easily replaceable . Cost of board is about $150.00 .
Posted on Jul 18, 2010
Does not make ice
Either the ice maker is not calling for water or the ice maker water valve is not working, there are many different types of water valves so its very dificult to tell you what to do without a model number or picture of the valve, but generaly speaking if you VERY CAREFULLY put 120V to a water valve it should open and alow water to flow, you can try this for the valve that has a water line going to the ice maker and see if it lets water go to the ice maker, sometimes there are two valves that must open, one main valve and then another for either the water dispensor or the ice maker. a better first test might be to test the water valve for resistance across the coil and compair it to another coil and see if its close-ish. also you can test some ice makers and see if they are putting 120V to the water valve by bypassing the bimetal and causing the ice maker to go into a cycle, but again a model number is required to know what kind of ice maker you have., even a picture would help
Feb 08, 2013 | Kenmore Sears Tempered Glass Shelf Refrig...
Jul 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Dec 26, 2009 | GE GSS25VFPWW Side by Side Refrigerator
Ice and water stopped dispensing
some models of this refrig have a lcok out feature on the dispenser look for a padlock symbol on the dispenser console and make sure its unlocked. if it s not locked out you may have a broken switch bracket behind the console cover. when you press the levers listen very closely and you should hear a click noise letting you know the dispenser switch has activated. Let me know if you have any further questions thanks Peyton
Mar 07, 2009 | Whirlpool GD5SHAX Side by Side...
My fridge is a side by side whirlpool, and it has a water despenser. The water despenser and ice maker isn't flowing, there is no water, no ice. Im not sure the model #.
check your water supply is ok and replace your water filter if it has one this should solve you problem if not then its poss you have bad water solenoids but not likely. peyton
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Broken ice maker in whirlpool side by side refrig model no.ed2ghgxmq00
1. Check freezer temp. Above 5 degrees? Icemaker will not start. 2. Make sure there is water coming to the refrigerator from the supply line. 3. Is the refrigerator clean underneath? Fan running? Dirty refer bottom can cause high freezer temps, see #1. Ideal freezer temp is -5. Icemaker and valve should be checked by a service tech.
Jun 26, 2008 | Whirlpool ED2FHSS Side by Side...
Kenmore elite side by side refrigerator
do you hear the little click of the switch when you push the paddle?? Its likely that the microswitch had broken from its plastic mounts. Pretty common on this refrig. ill need the model # to be sure what kind it is.
Nov 19, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
