Akai pa 750 - Audio Players & Recorders
CB Plays out PA Speaker
it is possible that the PA speaker output is intended for a normal (unpowered, unamplified) speaker. Perhaps in your case the audio you hear from the PA speaker is only signal leakage from the PA Speaker connection.
To know.. connect a regular speaker to the PA speaker connector (any speaker, home audio, old car 6x9....). If the PA works and drives the temporary speaker OK, and you hear no CB receive, then the PA output is for a normal speaker, with leakage of CB audio.
It is just a guess, but easy to try.
May 04, 2014 | Radio Communications
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
Good afternoon, i am looking for an akai setup code for the lct3201ad tv/dvd combo for my comcast remote control. thanks, mike
Mike, there is another solution: if you subscribe for comcast cable, they will retrieve the code for you, without you leaving your place.their remotes are learning and can be programmed remotely via you cable box. If you don't have a valid subscription, there is a problem. You might need to get universal remote, what supports this brand.
good luck,
Alex's TV Service,
Philadelphia,Pa,
215-806-5980.
Jan 22, 2010 | Akai LCT3201TD 32 in. LCD Television
The language on my printer screen is spanish, I don't know how to change it to english
follow this steps Go to Menu > Maintenance > Set Language & Country/Region > Press Start for English > hope this helps
Sep 01, 2009 | HP PSC 750 All-In-One InkJet Printer
GEM SOUND PA-750 POWER AMP
Hello plumer,
Locate a small slide switch at the back panel of your amp.
3 terminal and if you've snapped one of the wire, you'll see where the wire goes. But if it is 2 wire and using a ribbon type, follow the arrangement of the wire. No harm to the amp if you make a mistake. if bridge, all power will be shifted ti the left channel.
Good luck,
Mar 23, 2008 | Audio Players & Recorders
WOn't turn On
I talked to an Akai certified tech who told me the problem is a bad convergence module. The part alone is $400. Fortunately, I purchased mine from Costco 3 years ago. Costco has a 100% guarantee policy that I was not aware of. I called them asking if I had an extended warrenty and they gave me the full purchase price as a refund ! If any Costco purchasers are experiencing this problem and you purchased the TV prior to March 2007 (when Costco changed their policy), you may be able to take it back and get the full amount you paid for it. I turned around and purchased a new, larger Panasonic for under $150 more. It has a 5 year warrenty.
The Akai service number (to reach a certified repair place) is 1-800-726-4405. The Akai people are very good and can direct you to options. For those near Pittsburgh PA, Contact Rosewood Audio in New Castle 724 654-3023.
KW Pittsburgh
Dec 24, 2007 | Akai PT5598HD 55" Rear Projection...
Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Oct 30, 2007 | Akai LCT3285TA 32 in. LCD Television
 Grubhead
Grubhead
