Sharp color television
My television has standby power
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Stand by power means your tv is connected to mains but power not reaching to circuit. 1 please check power supply. 2 if it is ok check for horizontal section. 3 loose contact &loose connector. good luck
Posted on Sep 29, 2007
SOURCE:
My standby/timer light is flashing and will not turn on.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 02, 2011 | Sony KV-27S66 27" TV
Sony LCD turns off 34 flash turn on 30sec repeats ...
The self-diagnostic function of the projection television will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue, some of which you may be able to resolve without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the television may be overheating. To resolve this issue, ensure that the back of the television is well ventilated.
NOTE: If the television will not turn on immediately after being turned off, wait for the fan to finish its cycle, then attempt to turn it on again. This is part of the cooling process of some projection televisions and is normal operation.
If the flash sequence is not listed above, or the light continues to flash after troubleshooting the indicated issue, follow the steps below to perform a power reset on the television:
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
lno2()
Dec 14, 2007 | Sony Grand WEGA KF60XBR800 60" Rear...
Standby light blinks 4 times
Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Standby time light on and keeps flashing
May 21, 2011 | Sony FD Trinitron KD-36XS955 36" TV
Standby light keeps blinking but no picture
May 01, 2011 | Sony KP-53S65 53" Rear Projection...
Kdl-52xbr4 5 blinking standby lights
Dec 15, 2010 | Sony KDL-52XBR4 LCD Monitor
Red blinking light
Aug 14, 2010 | Sony KP-53HS10 TV
Thomson 32WZ610s television stays in standby
It the power inverter supply board 90% of the times.Very comon with LCD tv's design flaws in power inverter boards.Many,not all use the
same designs.
Aug 24, 2009 | Televison & Video
Standby power usage of the 42" Vizio Gallevia?
According to a Cnet review of the 42" Vizio Gallevia, the standby power usage is only .75 watts. Because it is so low, I now have no concern about leaving the set in standby mode. Virtually no savings to be realized by unplugging the set between usage.
May 18, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
MY sony wega 40 inch won't turn on
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
Jan 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
148 people viewed this question
Top Televison & Video Experts
Ekse
