Question about Sharp EL-1192G Calculator
How to install paper - Sharp EL-1192G Calculator
Alarm light
Paper Jam:
Clear the paper jam.
If the printer does not automatically resume printing, press the control panel button.
No Paper/ Misfeed:
  • The paper cassette may be out of paper or not properly installed.
    If it is empty, load a new stack of paper into the paper cassette.
    If there is paper in the paper cassette, make sure it is straight.
    If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
  • Reduce the amount of paper in the paper cassette, and then try again.
  • Make sure you use paper that meets Brother's recommended paper specifications.
  • Re-install the paper properly, and then press the control panel button. The printer will start printing again.
May 06, 2013 | Canon PIXMA MP495 InkJet Printer
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
I don't know how to install the paper
Place the paper in the tray on the bottom of the printer. When a printer says "Install the paper" It doesn't really mean to install per say.. just means to put paper into the tray.
Mar 29, 2011 | Computers & Internet
Hi i have a canon MP210 and it is showing E2 and the alarm lamp is flashing. there is ink and paper in it any suggestions??? I can't find the user manual!!
E2 – No paper, Paper does not feed error.
How to correct, fix: If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Nov 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer is not running while the power cord is ok.
Epson says....
Why is the printer beeping three times and the Paper Out light is on?
This indicates that the printer is out of paper. Make sure the paper release lever is in the correct position, then install the paper and try printing.
Q: Why is the printer beeping three times and the Paper Out light is on? A: This indicates that the printer is out of paper. Make sure the paper release lever is in the correct position, then install the paper and try printing.
Sep 30, 2009 | Epson LX-300 Matrix Printer
Installing paper
The printer loads paper from the installed paper tray or the manual feed slot.
For ordinary tasks, though, you would use the paper tray. This is located in the bottom front of the printer and looks as a kind of drawer. Pull it open to feed the paper.
You can download the User's Manual for your printer from Brother:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
I am assuming you have a printer
Aug 26, 2009 | Office Equipment & Supplies
Close drawer...
Take paper draw out of the machine you mite have paper behind the draw preventing sensor monitoring that draw from working properly. Mite get some can air an get any paper dust off the sensor for that draw. Is paper properly installed and are the paper guides securing the paper properly installed? Don't be storing additional paper in the draws. Is paper in the draw matching what is on the operators panel.
Aug 15, 2009 | Toshiba 2060 Copier
I have a Canon Pixma MP145 showing error E2. There's paper in the printer. After I turn it off then back on when the cartridge gets over to the right hand side (at the end of the back and forth thing it...
Jun 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Installing paper
Some machines have a lever on the side where the paper goes I'm not sure this one does but if it does pull the lever towards the front of the machine load paper then push lever back then you are done.
If the machine hasn't got a lever then some machines will need the start button or stop button to bee pressed after the paper has been installed.
Hope this helps you
Thanks J
Jan 04, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Sharp EL-1192G Calculator Logo
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
