Question about Sanyo Vpc-s1070w Digital Camera
Lens error 0x04110000 - Sanyo Vpc-s1070w Digital Camera
5 Suggested Answers
  • 420 Answers
SOURCE: When I turn on the camera I get a lens error
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Posted on Sep 11, 2010
  • 11967 Answers
SOURCE: lens error: 0x04110000
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 09, 2010
lock123
  • 6831 Answers
SOURCE: it shows lens error 0x04110000 and then it shuts
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Jan 25, 2011
lock123
  • 6831 Answers
SOURCE: sanyo digital camera s1070 when I turn it on it reads lens error
Hello
Regards
Andrea
Posted on Feb 13, 2011
Lens error 0X04110000 pentax optio e60
I am getting the same error on our Pentax Optio E60 . It says lens error: 0x04110000
Does anyone know what to do to fix it?
Jul 06, 2010 | Pentax Optio E60 Digital Camera
When I turn on the camera I get a lens error cx-0x04110000
try these:-
  • shake it.
Aug 16, 2009 | Sanyo Xacti VPC-T1070 Digital Camera
Lens Error: 0x04110000 This is the exact error that displays when I power up, then it shuts off.
try these:-
  • shake it.
Aug 09, 2009 | Pentax Optio E60 Digital Camera
It should still be under warranty. You are probably going to have to send it off to Pentax. A call to their tech support may give you the actual meaning of th error code, but more likely they will tell you it is broken.
Jun 23, 2009 | Pentax Optio E60 Digital Camera
Pentax E60 Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 09, 2009 | Pentax Optio 50 Digital Camera
Lens error 0x04110000 when camera turned on
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 16, 2009 | Pentax Optio 50 Digital Camera
Pentax optio e60 lens error 0x04110000
je viens de resoudre le probleme sur mon pentax E70L avec un simple aspirateur domestique,a l'aide du tuyau le plus fin, en realisant un nettoyage minutieux, tout autour de l'objectif, (sans rien demonter, evidemment!), ensuite le code lens error a changé, puis j'ai continuer a ouvrir et fermer l'appareil, a tenter de changer les options "scene", et l'appareil ne s'est pas refermer !...et j'ai pu refaire des photos!...soulagé!...l'appareil n'avait pas 2 mois!..mais rappelons nous qu'il n'aime pas le sable!
Mar 17, 2009 | Pentax Optio E60 Digital Camera
Sanyo Vpc-s1070w Digital Camera Logo
24 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
