Question about Health & Beauty
Braun series 3 330 spring popped out of trimmer. how do I replace?
SOURCE: Braun Pulsonic Razor - Pop up trimmer will not retract entirely
I ran into this problem several months ago. I just shook it and forced it until it retracted and never thought anything of it. The trimmer recently broke (still functioned but extended beyond its normal point) and I took it apart. I realized that there were a few broken parts inside (possibly because of my earlier experience). So I removed the few parts and now it still extends to far, but otherwise functions ok if I'm careful.
I would recommend taking yours apart and seeing if you can find any parts floating around which may be causing it to not retract all the way. It may be broken beyond complete repair, but you may be able to get a little more use out of it.
If nothing else, you can order a new casing for it from here
Here are the instructions for taking it apart:
The shaver itself is easy to take apart. The part on the bottom(opposite from the shaver mechanism) pops off with just a slight bit ofprying. Be careful not to break the pins though. Once you have thatoff, the narrow sides pop off pretty easily. Then you can remove the 4screws opening up the interior.
Be careful at this pointbecause there are a lot of parts that may fall out. (Perhaps take apicture as soon as you open it so you know where everything was whenyou opened it). At this point you can try your hand at fixing it (minehad 3 parts broken and loose inside), or you can simply switch it withthe new casing (Which i'm going to do when I get it). Good Luck!
Posted on Mar 31, 2009
SOURCE: Norelco shaver 800RX The spring on the pop-up trimmer came out
The spring has two coils, one at each end. They need to be pushed, hard, into the plastic tabs. I heard each side 'click' in. I wasn't pushing hard enough at first.
Posted on Aug 30, 2009
brector3
  • 1600 Answers
SOURCE: Would like to send back
The instructions for returning the shaver to Braun are printed in the user manual that came with the shaver.
Posted on Nov 28, 2010
e-Guru
  • 3917 Answers
SOURCE: HOW DO YOU FIX LONG HAIR TRIMMER ON BRAUN SHAVER
Hi
The trimmer is replaceable and can be purchased as an assembly. You will need a T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the old trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract.
Please get back to us if you have further query or else please accept the solution.
Posted on Sep 15, 2011
  • 3 Answers
SOURCE: Braun Cruzer3 trimmer not working / spring replacement.
Try this out:
Posted on Jul 30, 2012
Side burn trimmer won't stay closed on 790cc braun razor .
Almost certainly, the trimmer is broken and will need replaced. The part and replacement video instructions can be fount at shaveroutlet.com
Braun Pulsonic and Series 7 Shaver Trimmer Assembly
Jan 22, 2017 | Braun Health & Beauty
How to fix braun series 5 trimmer
Search Results
    Repair your Braun Cruzer 3 Trimmer MacGyver style in 6 ...
    ? 6:36
    https://www.youtube.com/watch?v=ZH1NRbDidRM
    Jul 30, 2012 - Uploaded by Ed el Vise
    My Braun Cruzer 3 Trimmer suddenly stopped working. ... I have replaced screens now on 5 different cell ...
    Braun series 3 razor fix - YouTube
    ? 3:00
    https://www.youtube.com/watch?v=mSdJu_iaEjs
    Oct 16, 2014 - Uploaded by mruberg1
    How to fix the Braun series 3 razor, after the trimmerattachment, falls off, due to sonic weld failures ...
    Braun Series 3 disassembling trymer rozbieranie - YouTube
Jan 18, 2016 | Braun Health & Beauty
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 screws
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Need braun series 7 blades
The blades come mounted in the screen assembly. You will find this cartridge available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
Aug 15, 2011 | Braun Series 7 9585 Hair Trimmer
Braun series 3 shaver small spring has come out of trimmer.Needs repair.
I left this for a while and used just one side of the foil, and as I was about to buy a new one I thought I'd give this a try - a weird idea.
Try cutting a pen's spring (at the end) to a similar size to the spring and try putting that under the plastic clip. It's worked for me!
Aug 03, 2011 | Braun Health & Beauty
Repair / replace trimmer on braun 9585 shaver
This part is only available from a Braun repair center. You can call a repair center at 847-869-7755
Sep 03, 2010 | Braun Series 7 9585 Hair Trimmer
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
Health & Beauty Logo
47 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
