Question about Sharp CD-ES777 Shelf System
Cannot change station on tuner--I have lost the remote
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
I lost the remote to my denon avr 3600 receiver....how can i change the stations on the tuner???
I just tried doing it on mine from the panel and I could only change the presets
Oct 24, 2009 | Denon AVR-3600
Satelite tv through my dvr-550h
satellite tuners and DVDs have different remote,unless your using a universal remote with satellite tuner command available.to program recording, you'll need to program the time especially the allotment.then make sure you sat tuner is tuned to the station you want to record.after setting the time and station, its all set.you don't need the DVD's remote to change the channel.
May 27, 2009 | Pioneer DVR-550HS HDD Recorder
Trying to find remote or is there another way to get all stations on this t.v without the remote
You can try to buy a samsung universal remote, buy a samsung vcr which has a tv/vcr switch, and this will let give you control of the tv and also allow you to program the channels. Because the vcr acts as a tuner.
May 11, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Switch to DTV -- how can I watch one program and record another
Unless the box has two digital tuners in it then I believe what you are trying to do is impossible. Find out first if it does have two digital tuners.
Jan 12, 2009 | Televison & Video
Radio without remote
Press Function button at front of unit until display shows Tuner, and press Preset + / Preset -
If you want to listen Non-Preset stations, press << / >> keys of remote to tune a station. That's the procedure.
If built-in remote in your mobile have above said << / >> keys, you can tune station frequency.
Nov 10, 2008 | Audio Players & Recorders
Reset channels??
http://www.eserviceinfo.com/download.php?fileid=26004
http://www.eserviceinfo.com/download.php?fileid=26005
Here are the links for the manual. I've lost my remote as well. I can't get my unit to recognize the digital audio input (optical). Very frusturating.
Apr 28, 2007 | Denon AVR-2700 Receiver
Sharp CD-ES777 Shelf System Logo
53 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
