Question about Haier HPR09XC7 Portable Air Conditioner
Haier HPRO9xc5 sounds like the fan has displaced inside. Sounds like it is hitting the sides of the unit inside.
3 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: ++HAIER 3125. Fan shuts off.
hi! there it seems that your control circuit board is activating default set up or abnormal set up after recieving on control circuit board when you shut off the unit, there's a short circuit behind on holding relay when deactivation process is done, the holding relay should be cutting your entire source connection on compressor terminal when you shut off the unit, in this case try to isolate checking supply voltage behind relay and the supply source terminal of your relay, .try to check on this to your manual circuit diagram to lessen the complication of trouble shooting just focus on relay circiut,replace relay if defective.this is a hard job and should be done by qualified a/c technician. have a nice day regard and thank's a lot
Posted on Mar 30, 2009
  • 884 Answers
SOURCE: Haier CPN14XH9 units not working
#1 Compressor fault, may be capacitor relay. #2 no gas or fan faulty (not working)
Posted on May 01, 2012
May 01, 2012 | Haier HEATER CPN12XH9 Air Conditioner
Window / through wall unit made by haier, i can't find a model number. but it's making an awful racket like a blade or something hitting something. also slightly blows out a light fine mist of...
Where the unit drains is clogged it sounds like so your fan blade is hitting the water and scooping some of that water indoor. look where the condensate drains and clean that and it should be fine
Aug 14, 2011 | Haier ESA3125 Wall/Window Air Conditioner
When I turn the air conditioner off or on it makes a noise sounding like it is coming from the fan. It sounds like the fan might be loose but I'm not sure. What is the problem and what should I do?
Hello, you would need to take the top cover off the AC and check the fan, usually the hub of the fan breaks and becomes loose or sometimes just the clamp comes loose and the fan hits the housing. If the fan is cracked then you would need to replace just the fan on the unit. Here is a link or parts to your ac http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/ESA3109.aspx.
Jun 13, 2011 | Haier ESA3109 WallWindow Air Conditioner
My haier 8,000 btu window unit sounds like the fan is hitting the housing when it is installed in the window. the only way it doesn't hit is if you tilt in inward towards the inside of the windows inside...
Somebody is going to have to adjust the squirrel cage blower to keep it from hitting. This happens in a lot of heat/cool window units. Sorry probably not what you wanted to hear.
Apr 12, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
Dehumidifier makes a lould clanking sound when the fan spins. I took of the back cover, the fan is not hitting anything, sounds like it is coming from inside the motor.
Sounds like a bearing went bad. Unplug the unit and grab the fan blades and move them. If they slop around inside the motor, you have bad bearings.
Sep 28, 2010 | Fedders R6DH45X Dehumidifier
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Lasko 5365 heater making growling sound.
sounds to me like you have a fan blade hitting something inside the unit, or the motor is going bad, thats the only moving parts to the unit unless it has a sweeping mode, moves from side to side, if it doesnt have that, then its your fan motor or blade, you probably need to replace the motor or the whole unit, as they are fairly inexspecive, but its your call, look inside the unit to see if anything is in there that might be making the noise as well, best of luck, hope that helped
Jan 19, 2009 | Lasko 5365 Ceramic Compact Heater
Haier 5,200 BTU
there should be a rubber plug on the right hand side from the outside 2 black round " corks" if you see them remove them and your problem should be solved
Jun 15, 2008 | Haier Mechanical Air Conditioner HWF05XC7
Haier HPR09XC7 Portable Air Conditioner Logo
24 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
