Question about Olympus FE4020 Digital Camera
Factory reset my camera is new. It is fully charged. I can't turn it on even if I try to turn it on. Just a light will blink with an arrow on it then it stops. Please help.
SOURCE: camera won't turn on
My daughter FE-190 just had the same problem. Make sure the little red tab is locked over the battery. Hers now works properly. I think it is possible with this camera to put in a battery and it NOT have good contact.
Hope that helps Brian
Posted on Aug 06, 2008
  • 479 Answers
SOURCE: Camera won't turn on, just beeps
first check the battery... charge or replace it... else reset the camera or repair
Posted on Sep 05, 2008
dotball
  • 64 Answers
SOURCE: olymp c-5000 won't turn on red/ yellow lights blink/ beep 20 time
Furrybutts (hehehe, like the name), This could be a lot of things and I'm sure there's a service guide out there that will tell us what 20 beeps and flashing lights mean, as I don't have one, let's figure it out.
Firstly, digi-cams and rechargables, eerrrrrgggg (Mr Burn's shudder) yeah they 'work', but for trouble shooting and iffy times, lets look at some half desent NEW alkaline batteries - for about $3-$4, it's worth it for this troubleshoot.
OK, did they work?, No?, lets look at the memory card. The cards are supporsed to be only put in one way, but ... lets take out the card, clean the contacts with a clean cloth/tissue, and put the card back in being sure it's in the right way. Still no go?
Take the card out again and try and turn the camera on without the card. Any changes?
This camera uses an XD memory card. I can't remember if it has an internal memory - what we're looking for is whether the memory is damaged and the camera is happy using it's internal memory or still erronous with no memory. Do you have access to another XD card to try it (this camera will take a MAXimum of 512mb, so don't try and card bigger).
Lets leave it at this for now and you let me know how things are going?
**.The best way to acknowledge contribution is to rate it's relevance.**
Posted on Feb 02, 2009
joemxavier
  • 342 Answers
SOURCE: The camera is suddenly not working. Battery was
this is due to the software errors of the camera
Posted on Jun 11, 2010
Testimonial: "any way to fix it or is it done for?"
SOURCE: My Olympus 7010 is fully charged. When I turn the
I fixed the problem by pushing the lens just a bit from the side when turning the camera on.
Posted on Jul 13, 2010
Kodak easyshare digital camera MD41, lens extends and closes when start button is pressed with fully charged battery light blinks red and turns off camera
hi open the battary comparment, remove the battery and check to see if there is a small button like thing (looks something like a small horn) there if yes then, press and hold it for roughly 20 secs and release reinsert battery and try powering on this would reset the camera to original factory settings at a hardware level
(i got my other Kodak c340 to work this way)
hope this helps
cheers
May 05, 2011 | Kodak EasyShare MD41 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
SONY Digital Camera DSC-W50 doesn't work. Lens goes in and out...
Hi!
Please try the under given troubleshootings:
(i) Please check if the Battery is fully charged.
(ii) Next, turn off the Camera, remove the Battery pack then press and hold the Power button for 30 seconds.
(iii) Then, reinsert the Battery pack and turn ON the Camera.
(iv) Next, try to access the menu options either by directly pressing the menu buttons or while reviewing the images.
(v) If the menu options are accessible while reviewing the captured images then reset the Camera to the original factory settings.
Please follow the steps given below to reset the Camera to the original factory settings:
(a) Turn ON the Camera.
(b) Access the menu screen either by directly pressing the Menu button or pressing the menu button while reviewing the captured images.
(c) If menu screen is accessible, then press the right arrow on the Control button to select (Setup) Settings, then press the right arrow again.
(d) Next, select the Setup 1 option by using left/right/up/down arrow on the control button.
(e) Then, select Initialize and OK.
(f) Finally, follow the on-screen instructions to set the clock in the Camera.
Performing the above steps will reset the Camera to the original factory settings. If the issue persists even after performing all the above steps successfully then the issue is related to hardware malfunctioning and service is required.
Please feel free to contact for further information or any clarification.
Aug 21, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
When i turn on my camera the lens goes in and out but it wont let
Hello!
First, check if the Battery inserted in the Camera is fully charged. If not then charge the Battery to its fullest then insert it in the Camera to check its operation.
Next, remove the Battery from the Camera then press and hold the Power button for 30 seconds. Then, reinsert the Battery pack in the Camera and turn it ON and check its operation.
Finally, please check if the menu screen is accessible by pressing the menu button directly or while reviewing the captured images. If the menu screen is accessible then reset the Camera to the original factory settings.
(a) Please press the menu button directly or while reviewing the images to access the menu screen.
(b) Then, press the right arrow on the control button to select Setup option.
(c) Next, use left/right/up/down arrow on the control button to select "Setup 1" option.
(d) Then, select the "Initialize" and OK.
(e) Finally, follow the on-screen instructions to set the clock on the Camera.
performing all the above steps will reset the Camera to the original factory settings.
If, even after performing all the above steps, the issue persists then the issue is related to hardware malfunctioning and service will be required.
Aug 21, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera will not turn on...charged battery but the charge light blinks instead of staying solid
If battries still blinking , chances are that the battries are buggred...try new battries after fully charging...this is cheaper option to try before trying to open the camera..
May 20, 2009 | Casio Exilim EX-Z77 Digital Camera
My problem is the flash of my olympus fe-230 does not work even if it is in the automatics status. the red flash sign just pop up at the left side of the screen while capturing pictures. i already res
Have you tried to reset the camera back to factory defaults to see if it is maybe a setting that has the flash disabled? To reset the camera: go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will put the camera in factory default settings. See if the flash works now. If you see a red squiggly flash arrow blinking on the screen constantly, this is actually a repair issue and the camera would need to be serviced to replace the flash charging indicator switch. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 21, 2009 | Olympus FE-230 Digital Camera
MY OLYMPUS FE-115- THE FLASH DOESN'T GO OFF
You can try to reset the camera back to factory settings to see if the flash will start working again. To reset: Have the camera in shooting mode - press the down arrow - camera will indicate reset or cancel - highlight reset and press ok - the camera will be back in factory settings - see if flash fires - if it does then fine - if you see a red flash charging icon blinking on the screen this is a repair issue and the camera needs to be sent to Olympus for service.
Apr 12, 2009 | Olympus FE-115 Digital Camera
Kodak Easyshare Z760 orange light flashing
The flash does not charge separate from the rest of the camera. Try cleaning the flash sensor on the front of the camera or the flash led may be bad.
Secondly, this light functions as a flash sensor which is trying to tell you that you need to use a flash although you may have the flash manually turned off. looks like a bolt of lightning with a circle/slash through it.
May 09, 2007 | Kodak EasyShare Z760 Digital Camera
Olympus FE4020 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
