Question about Philips Televison & Video
My Philips 42pfp5532d keep tripping a couple of seconds after I plug it in I don't even have time for the tv remote to take the tv off standby before it trips. When I plug the tv in there is a green light inside the back of the tv you can see through the back after a couple of seconds it trips and the light goes off and then comes back on flashing any ideas ??
jerryg50
  • 1667 Answers
SOURCE: plasma wnt stay on
I have had this problem in some models of plasma sets before. In most cases the power supply and main drive boards had to be replaced. In a small number of cases the failure was the screen itself.
In all cases, the cost of the repair was expensive. For the screen failure, the set was scrapped.
Jerry G.
Posted on Apr 12, 2008
mistersony
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
SOURCE: Hi we have a 42in philips matchline flat tv. When ...
mine is doing the same.... any solution to fix this problem?
Posted on Sep 27, 2010
Hi all could someone help me please I have a philips 42pfp5532d and its stuck in digital tv and when I press menu nothing comes on the screen . What do I need to do ??
Search or call Phillips and see how to reset the TV back to the factory settings. Sometimes its as easy as hitting a couple of keys on your remote. Good Luck
May 02, 2016 | Philips Televison & Video
Nec resetPX-50XR5W
Hmm - does this still happen even if you reset all the settings on the TV to factory default? Other things might be;
1) You're the victim of a prank.
2) Try and use the buttons on the TV to navigate the menu screen, instead of the remote.
3) Call NEC support. They'll usually help with this even if its not on warranty.
-GWOOD
Jul 14, 2014 | Office Equipment & Supplies
Tuning tv using universal remote control bd 512
Check this link to download the user manual to this remote control. It has all details.
bd 512 instruction manual edited
Feb 06, 2014 | Philips Televison & Video
My 42 inch philips (42PFP5532D) has blank screen but blue light to show its on but nothing on screen :(
just let me know if their is a sound when you turn on the tv then the only problem is black screen. if you can get sound tried to press the channel up/down button let see if you can get a channel. if you hear that receive channel that was mean the problem is either the screen back light get busted or the power inverter is defective. hope this can help good luck.
Nov 02, 2012 | Televison & Video
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
Feb 04, 2012 | Philips Televison & Video
Philips 42pfp5532d 05 plasma tv won't store tv channels. when turn off then back on has to scan for tv channels again.
I had the same problem a little while after the digital change over, channels were all lost struggled to get the set up menu up but when i did i retune the channels as soon as you turn the tele off there lost again. but it works if you leave the tele on standby. 2 people have told me it's the battery in the tele itself.
Aug 26, 2011 | Televison & Video
How to reset my Tv Plasa Philips model 42PFP5532D to factory (hard reset) ?
To reset to the factory default settings, press and hold down the MENU key on the side of the TV set for 5 seconds. A menu will appear on the screen with language and etc. If you want to, set everything like it was your first time with the tv.
May 26, 2011 | Televison & Video
Philips 42PFP5532D/ MAKES THE NORMAL CLICKING NOISE WHEN YOU TURN IT ON . BUT IT CLICKS BACK OF AGAIN SO YOU DONT EVEN GET A PICTURE ALL YOU GET IS THE RED STANDBYE LIGHT FLASHING DO YOU NO WHAT THE...
philips tv's test them selves when turned on if something is wrong it shuts down you need a tech to determine your problem more than likely it is you power supply
Sep 18, 2009 | Philips 42PFP5332D 42 in. Plasma...
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
No Pictre, Flashing Power LED - Philips 42PFP5532D Plasma
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 20, 2009 | Televison & Video
Televison & Video Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
