Philips fwp78 with Comcast universal remote
I have a Comcast Xfinity universal remote and I have programmed it to the correct code for my Philips FW-P78 stereo system and I can turn the power off on the system. However, I cannot turn the power back on. It seems you have to press the AUX button on the stereo system in order to power it on fully to the point that it works and I have not found any buttons on the remote that will substitute this function. Is there any way around this or to solve this problem?
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Never expect all the buttons on a universal remote control will work, as it meant for. What you can do is, to check an other code to your set, and set it up with the remote control. And an other one. In this way, check all the codes, and choose one code, which give you maximum functionality. That's all. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 22, 2013
SOURCE: Codes for my Philips universal tv remote control
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Posted on Jan 02, 2008
dauphine
  • 207 Answers
SOURCE: programing philip universal remote to my tv
You can find the instructions here. Just follow the step by step instructions to properly select model of your Phillips remote. http://www.urc.philips.com/
Posted on Apr 10, 2008
aprmaejun
  • 97 Answers
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jul 29, 2008
SOURCE: Help with comcast remote code setup for philips tv
Try adding 1 to the front of the code. 10054 worked for me. Hope this helps.
Posted on Nov 26, 2008
  • 5 Answers
SOURCE: need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Posted on Jul 17, 2009
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
Jan 27, 2016 | Element Electronics Televison & Video
Need codes for my comcast remote
Comcast Remote Codes ' Program Your Remote Control
https://customer.xfinity.com/remotes/
Help and support with your XFINITY® Remote, select your remote control type and get the support you need to enjoy your XFINITY® TV!‎Comcast - ‎Find Your Comcast Remote ... - ‎Control Multiple Devices with a ...
Remote Control Help and Support ' XFINITY® by Comcast
Jan 18, 2016 | Televison & Video
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
Jan 01, 2016 | LG Televison & Video
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
Dec 28, 2015 | Philips Televison & Video
How do I program a comcast xfinity remote for a Dynex tv
Hello there
From this page, http://customer.comcast.com/remotes/
I used the first type of remote and I got
  1. Turn on the TV you are programming.
  2. Press and release the "TV" button on your Universal remote.
  3. Press and hold the "Setup" button on your remote until the button blinks twice.
  4. Type in the 5-digit code using the number buttons. Most likely code
    11463 Others to try
  5. If the code is correct, you will get 2 blinks. If the code is incorrect, you will get one long blink.
  6. Use the Universal remote to operate your TV (use Power, VOL, etc..)
  7. If these steps don't work, look for another code and repeat the above.
Sep 20, 2014 | Samsung TV Remote Control
Xfinity remote setup
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 03, 2014 | Comcast XFINITY
I need a comcast remote tv code for a AMP'D tv
For the comcast xfinity remote use the philips code 11454 from the lcd tv section. That is the code that I got to work
Nov 08, 2013 | Universal Remote Control Remote Control
Remote code tvremote
Do a Google search on "Philips BDS-4611 remote control" and you should find a used one, new one, or universal remote that can be programmed to work with it.
Oct 21, 2013 | Philips BDS 4611 46 in. Plasma Television
Need help finding DVP3140 remote programming code for comcast universal remote
Since the codes that Comcast gave you did not work, there is a very high possibility that the remote control is not compatible with the DVD player. You cannot expect universal remote control to work with all devices, regardless of its make. Philips does not have codes for this DVD player because it is the maker of the universal remote control that sets the codes.
Mar 24, 2008 | Philips DVP3140
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
