Question about Singer Sewing Machines
My needle hit one of the pins holding the fabric together. Usually it snaps the needle in half and I just replace it. This time, it jammed down inside the bobbin housing and I couldn't lift the needle up or own. I cut the needle in half with tin-snips and removed the needle, but now the needle arm is jammed and won't go up or down. HELP! I need to finish my son's Halloween costume by this Friday!
    Habit-Forming:
    New Friend:
  • 60 Answers
Remove the faceplate, bobbin and case. See if you can see the bottom part of the needle. Use a flashlight to look down in the bobbin area. Put a magnet on a pair of long tweezers to magnify it. You can then gently move the tweezers around to grab hold of the broken needle.
Posted on Aug 04, 2017
  • 192 Answers
SOURCE: Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Posted on Nov 14, 2007
SOURCE: Adjust timing on Singer Merritt 4530
what size replacement needles for a singer merritt 4530
Posted on Nov 15, 2008
  • 4 Answers
SOURCE: how to re-insert bobbin shuttle
maybe one of the parts diagrams at the Singer site would help? or us the contact there?
Posted on Nov 30, 2008
Obertelli
  • 3006 Answers
SOURCE: The thread is bunching up
Your problem stems from the faulty foot lever mechanism. It's coupled to the upper thread tension control which only provides tension when the presser foot is in the locked down position.
If the presser foot won't positively engage in the down position, there's no upper thread tension and the thread bunches up below. Everything else stems from there. If the needle has hit the bobbin case too frequently then the bobbin timing may also be slightly out and the needle itself will be damaged and won't pass straight through the fabric; it only takes a tiny deflection from the vertical as it passes through the workpiece for the needle to flex and hit the bobbin case.
In summary, your machine is in desperate need of repair and adjustment. You haven't stated which exact Singer model you have, but they are usually easy to get servicing manuals for or you can take the machine to a sewing machine servicing specialist. Most singer spare parts (even for 100 year old machines) are usually still available fairly cheaply from a variety of sources, just enter "Singer spares" into your search engine to find suppliers.
To prevent re-occurrence, clean the mechanism regularly and lubricate it as directed by the manufacturer using sewing machine oil. Depending on how often you use the machine, do (or have done) a more thorough service periodically to check the timing and also that all mechanism screws remain tightly fastened.
I hope that my reply has shed some light on your problem and enables you to decide what to do next. Please take a moment to rate my answer.
Posted on Sep 30, 2010
  • 10 Answers
SOURCE: Needle breaking, hitting bobbin case
I had this problem and it is very easy to fix!
With mine I looked at it for about half an hour, and all I needed to do was put the bobbin case back in,(how it fits normally) and then hold it and turn it anti clockwise until it clicks, it may be quite pressured to do but ive heard a lot of people having this problem and thats all that needed doing!
Hope i helped! :)
Posted on Oct 28, 2010
How to sew Lycra on my necchi 522? I'm using a stretch needle. It goes up and down, fabric advances, but does not pick up bobbin thread - so no stitches!
Knit fabric sometimes plays a little havoc with machines. Be sure you are using a brand new needle. Also, ballpoint/jersey needles will usually work better with knit fabrics like t-shirt fabric. For very stretchy fabric like Lycra, you might want to try a Stretch Needle.
Schmetz Needles Needle Guide
Sewing Spandex Tips
If it still will not stitch, check your machine on regular woven fabric with a universal needle. Could be your machine is slightly out of time, especially if you have recently sewn over & hit a pin.
Oct 26, 2016 | Necchi Sewing Machines
What caused my empisal 760c over locker to have a timing problem n how can I solve it? Would a new from the box over locker have timing after one use?why
Timing issues are usually caused when the needle hits something it shouldn't, ie a pin or if the sewist pulls the fabric while stitching or the fabric is too thick and causes the needle to bend....
There are web sites and videos on the internet explaining how to address sewing machine timing issues. Or, take it for service.
Aug 14, 2016 | Sewing Machines
Hand held sewing machine
I think you are saying no stitch is formed also referred to as the needle not catching thread. Below offers a variety of diagnoses and solutions which are straight forward.
Sewing Machine Needle Not Catching Thread
Below is general advice quoted from 6 common sewing machine problems solved:
Skipped stitches are usually due to a bad needle. The needle may have become damaged or bent by sewing material too thick for the needle, forcing material through the feed dog, or hitting a straight pin. If the problem seems to be consistently reoccurring, it may be due to forcing the fabric. Sewers should allow the feed dog to pull the fabric and only use their hands to guide the fabric through the feed. When sewing knitted fabrics, using a stretch needle can help prevent skipped stitches.
Below is a video showing how thread is hooked into a fabric:
Sewing Machine Anatomy How Stitch is Made
Jan 18, 2018 | Sewing Machines
How do I get Singer zigzag 457 to stop hitting the needle on the bobbin housing?
the sewing machine is out of time & needs to be retimed at a
sewing machine repair shop.
here's a link for a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Sep 11, 2012 | Singer Sewing Machines
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Check your needle plate and make sure it's securely in position.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Keep breaking needles
Here are some solutions to try.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
I am having a problem with my Shark Intell-Sew that I've had a few times before but I've always been able to resolve it, and this time I can't. The machine jams, and the book says it's usually because the...
Many machines today have a horizontal thread delivery for the needle thread. Be sure and place the thread spool with its tiny notch on one end (the notch is used to secure the loose thread end when not in use) facing toward the far right side of the spool holder and not facing toward the left side where the thread will be guided off the thread spool into the vertical tension discs and toward the needle. Some times this tiny notch will catch the thread causing undue thread tension on the needle thread. Placing the thread spool facing toward the right seems to help the thread guide off the spool without catching in the tiny notch.
Also hold onto the needle thread and the bobbin thread, giving slight hand tension to both, for the first few stitches you make in your fabric. With the first uptake of the needle, the needle’s thread tail and bobbin tail are drawn down somewhat loosely into the bobbin case and can become tangled and jam if not held onto briefly. Be sure the bobbin thread comes out of the needle plate in the area it is intended to. After winding a new bobbin, it may help to put the bobbin in its bobbin case and just raise the machine needle by hand just enough to allow the needle to bring up the bobbin thread to the top. Give the bobbin thread and needle thread held together a slight tug so that they both lay out behind of or to the side of the needle. If you have left off the needle throat plate for last (for those machines that allow the throat plate to be removed) when placing the throat plate back on the machine, be careful to guide the bobbin thread through the hole or space in the needle throat plate so the bobbin thread lies on top the plate.
Using the right machine needle for the fabric helps too. Generally, ball-point needles work great for knits and sharp-pointed needles for woven fabrics. Using the smallest size needle that makes the best stitch for the type of fabric seems to work well for most fabrics to produce clean even stitches.
Using the best quality thread helps. The bargain-priced threads found piled in sale bins at the fabric store work great for hand sewing but not for machine sewing. Lesser quality thread make lots of fuzz as it passes through the needle and can jam the machine. Many sewing machine repair folks hate the thought of us using a can of compressed air to blow out fuzz from the tiny spaces of the machine, particularly the newest digital electronic machines, but a spritz or two of compressed air in the vertical thread slots that hold the tension discs and in the bobbin case itself, usually can dislodge bits of fuzz from these spaces. Although compressed air is not recommended for a new machine the thought is offered for you to consider for older, mechanical machines.
Sep 12, 2009 | Euro-Pro Shark 60 - 384
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    If this doesn’t seem to be the problem
    Make sure it’s attached securely.
    Make sure it's securely in position.
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Sewing Machines Logo
26 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
