Question about Homedics Spa Reflective Illuminat Beauty Mirror M-10021 (Homedics)
How do I get a replacement mirror? - Homedics Spa Reflective Illuminat Beauty Mirror M-10021 (Homedics)
How to replace outside side power mirrors in original housing? 2008 Ford Edge
Google replacement mirror glass for Ford Edge 08.
They make a replacement mirror glass available that uses double sticky tape. This has worked great for me. The heated function still continued to work!! In my case I replaced a scratched mirror leaving the old mirror in place. If yours is broken included is a link for a procedure to replace a broken mirror.
Confirm the dimensions before purchasing. Some car manufactures have more than one design for different model cars same year..
26182860-kzssal3k2qlm4jsc53ab1s2h-2-0.jpg This is an easy repair.
How to Repair and Replace Broken Side Mirror Glass DIY
May 02, 2016 | 2008 Ford Edge SEL
How to replace wing mirror
Replacing Wing Mirrors - YouTube
? 4:06
https://www.youtube.com/watch?v=2LAqSfV-swI
May 23, 2010 - Uploaded by Decibel Car
Want to replace your wing mirrors with aftermarket ones ? Had someone in a shopping mall car park break ...
    Remove the screws that hold the mirror and remove it from the door. Attach the new mirror. Reconnect the electrical connector and make sure you test the new mirror before putting the parts back into place. Reverse the entire procedure to reassemble the door trim panel.
    Replace a Broken Side View Mirror ' The Family Handyman
    www.familyhandyman.com/automotive/replace-a-broken...mirror/view-all
Dec 02, 2015 | Cars & Trucks
How to replace sideview mirror motor on95 Riviera
You don't replace the motor. Replace the entire mirror. If you want to replace just the motor, you have to remove the mirror first and they break. Either the mirror will break or the tabs that hold the mirror to the motor.
Dec 05, 2014 | 1995 Buick Riviera
How can you replace just the mirror on my pontiac bonneville?
Find a glass replacement company that can cut the mirror for you. Be cheaper to get a junk yard replacement of same color.
Aug 28, 2014 | Cars & Trucks
Is it ok to put non heated mirror over heated mirror
The replacement mirror that you buy at most auto supply stores are not to be used as a replacement for a heated mirror due to fact that the materials used to make the heated mirror are different. You will need to replace it with the same type of mirror from the dealer.
Apr 18, 2013 | 2004 Dodge Grand Caravan
Replace side view mirror 2002 chevy tahoe
Once you've purchased a replacement mirror glass based on your specific make, model and year simply follow the steps below:
  • Remove all existing glass from the mirror head's plastic inner platform (backing plate).
  • Clean backing plate with rubbing alcohol. Clean back of replacement mirror with Burco Window Glo or other glass cleaner.
  • Apply the Burco Redi Stick adhesive patches and or silicone/urethane to the replacement mirror's back or to the backing plate itself.
  • Align and press replacement mirror to the backing plate.
  • Clean the installed Burco Redi Cuts mirror with Burco Window Glo or other urethane-safe glass cleaner.
Oct 09, 2009 | 2002 Chevrolet Tahoe
Mirror replacement
you can replace the mirrors with the standard power mirrors
Sep 19, 2009 | 2004 Nissan Titan
Side View Mirror replacement for a 2008 KIA Spectra
Insert flat bladed screwdriver between outside rearview mirror holder and mirror actuator. Wrap it with tape. It should just pop off.
Apr 11, 2009 | 2008 Kia Spectra5
How to replace side mirror glass and frame ? 2002 Chevy astro van
It should snap out and the new one snap in. Most auto glass companies can order just replacement glass from burco mirror. http://brokencarmirror.com/replacement/mirrors/
Nov 06, 2008 | 2003 Chevrolet Astro
Broken driver side mirror
You can buy replacement stick on mirrors at most auto stores... different sizes or you actually cut it to the size you want.... cut out a peice of cardboard to make a template till it fits right on the mirror on the car and use that to get the replacement mirror you need or cut the replacement mirror to size.... peel off the paper on the back... then line up the mirror and push firmly starting in the center of the mirror working outward to make sure the sticky side sticks.
Robert
Sep 23, 2008 | 2008 Chevrolet Cobalt
Homedics Spa Reflective Illuminat Beauty Mirror M-10021 (Homedics) Logo
41 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
