Question about Toshiba Gigabeat S30 MP3 Player
New battery and still wont work...
Ok Heres my problem. The gigabeat WORKS when plugged into an AC power source BUT doesnt work when attempting to run off the battery. When the ac source is plugged the battery charge indicator flashes for a second and then says battery is full. I have tried replacing the battery because it is out of warranty but still does not work. Any thoughts???
  • Baude Oct 11, 2007
    Mate You Think i havent tried that! Next Thought Please
  • betchabottom Dec 30, 2007
    I am able to play my gigabeat S60 when adapted to AC but not with the straight battery... it just turns off. I have tried the battery switch at the bottom and it's still not working??
    Please help
There is a little switch on the bottom of the Gigabeat (just to the left of the mini usb port on it).
Put a pin into the little dimple in the switch and make sure its pushed all the way over towards the USB port.
Posted on Oct 11, 2007
SOURCE:
Ac power doesnt work only in battery mode,adaptor output is ok
sounds like the power connector (where you plug into pc) is going bad. try twisting / wiggling connector. pause for a few seconds between twists to give circuitry chance to reconize power input. sometimes there is a green led that will light up when power adaptor is inserted. you can use that as a reference.
Jun 03, 2009 | Computers & Internet
MES60VK Gigabeat - Dead
There is a switch on the bottom left side of the dock connector of the player. Flick the switch to the right and it should work. The switch is the battery cutoff switch. It is there so it will charge only. I have no idea why Toshiba though this was a good idea, but they put it there.
Nov 08, 2008 | Toshiba gigabeat MES60VK Digital Media...
My toshiba MES60VK wont turn ON
I am having the same issues, any luck finding a solution?
Apr 15, 2008 | Toshiba gigabeat MES60VK Digital Media...
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
have you only been charging it with the usb cable?
try plugging it into a ac adaptor, (make sure the button is in the off position at the bottom)
and it should hopefully restart, then turn it to the on when it's loaded, and leave it plugged in till it's completely charged
that might work
Feb 26, 2008 | Toshiba gigabeat S MP3 Player
Gigabeat has froze completely
Turn off the battery with a toothpick or pencil then turn it back on. You can do this on the bottom side.
Aug 09, 2007 | Toshiba gigabeat S MP3 Player
Gigabeat frozen!
Hi Lorna, Yeah I found my Gigabeat froze a few different times when I was getting used to it. Solution: at the bottom of player there is a little battery on/off switch - its tiny and black but you would have needed to switch it on to first use it. Well turn it off here for 10 seconds and the on again. This removes all power from the hard drive and circuits which occassionally freeze. Hope that helps
Apr 23, 2007 | Toshiba gigabeat S MP3 Player
Reads syetem error
Well, there are two things you should do before taking drastic measures: 1) Turn the batter off for a few minutes, turn it back on and reboot. -or- 2) Try to connect the GB to your PC and re-load the firmware. -Very simply, just connect your GB with the USB cable only to your PC. -Open up Windows Explorer and locate the GB's drive letter (if available, it will look something like this (G:\GIGABEAT - if it isn't there after repeated attempts, skip to the "drastic measure") -Once you locate the drive, keep it in mind and now navigate to the C:\programfiles\Toshiba\Gigabeat Room\2 directory. -In that directory, you'll see a GBSYSTEM directory. Right-click "copy" (or drag 'n drop) it directly into your GB's drive letter and overwrite any existing files. -Unplug, power off and reboot. -If that doesn't work - reformat with the included Toshiba GB format utility and repeat (maybe repeat twice if it fails again - to confirm you did it right.) -If it still doesn't work - time for drastic measures (or taking it back and getting a replacement) DRASTIC MEASURES: ------------------------ Don't worry, it's not that bad and many of us have had to do it for some reason or another. If you're not comfortable taking apart your GB, then please don't do this. Take it back. If you feel confindent in your tinkering skills, follow the instructions EXACTLY as written : So you?re Gigabeat is stalled? Seems like you need to do a little Gigabeat Surgery in the form of a "Hot-Swap". Here?s what?s happening: When you hit the power button, you see the opening Gigabeat screen with status bar. The bar starts to move right like normal, but stops halfway and never moves again, right? So, if you want to fix it yourself? Ok, here?s how. You need to physically reset your drive so the computer will recognize it and you can put an operating system back on it. **This is the ONLY way you'll get it to work** ** DO THE FOLLOWING AT YOUR OWN RISK. ** Here's what you'll need: (not for the "mechanically/technologically challenged") 1) Phillips Screwdriver (smallest you can find) 2) Place to put tiny screws 3) Soft cloth for cushioning 4) Original Software CD (if you don't have it, google ios you're best friend !) 5)Patience **This will work and is not as hard as it seems, risk is minimal as long as you don't remove the front panel!! -------------------------------------------- Ok, here are the steps: (Read all before you start) 1. Go to this site and look up, these are images of the process: http://www.angelfire.com/bug2/gigabeat/ 2. Disconnect the AC adapter and switch the battery to OFF. 3. Only open up the BACK of your GB, leave the front alone, repeat DO NOT REMOVE FRONT!!!(Back slides down a bit, then out - don't force it, you'll bend the metal) 3. *GENTLY* disconnect the HDD according to instructions on the web site. (See below) 4. Connect the USB port on the GB to the computer. 5. Turn battery ON. 6. Wait for GB to error and show USB logo on screen. 7. Re-attach the hard drive WITH THE GB STILL TURNED ON! It's a usb drive so that kind of thing is ok. 8. Go to the GB drive in Windows Explorer and copy the GBSYSTEM folder to the GB as per the instructions in the manual. 9. Safe disconnect the USB device (as per Windows instructions) 10. Turn battery switch OFF. 11. Put your GB back together again. 12. Switch battery to ON. 13. Turn GB on. That should do it! And what is more after you use the library refresh tool in GRoom (select GB not PC in this case) you will have all your music back, too.
Jul 26, 2006 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba Gigabeat S30 MP3 Player Logo
76 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
JohnLong
Blake Whiteside
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
