Question about Electronics - Others
Dapc 6500 watt generator - Electronics - Others
5 Suggested Answers
  • 5603 Answers
SOURCE: yamaha 6500 watt diesel runs but usually shuts
First thing to monitor is the fuel solenoid power. See if it is the thing that goess away to cause shutdown.
Tracing this back there is only a few things that control this: The battery, the low oil shutdown switch, and the run switch, and associated wiring.
If I were to ventture a guess, I would put money on the low oil shutdown switch.
Posted on Sep 02, 2009
sal_kh_sab
  • 98 Answers
SOURCE: 6500 watt diesil generator /as soon as i put any
if by fliping the breaker it shuts off..that means there is a short circuiting in the breaker..try connecting your house,shop..etc..directly ...
that is if the shut off reason is overloading...if not please explaing with details
Posted on Oct 26, 2009
jyackle5
  • 8197 Answers
SOURCE: I have a Coleman mach3 rooftop and was wondering
For what you are trying to run a 6000 what will work. You will need a running watt of no less than 5000 watts.
The 7000 will work just fine.
Posted on Aug 26, 2011
palaboy
  • 5807 Answers
SOURCE: Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
Alternately,
• Turn-off all lights first.
Run your pump or water start motor.
• When the motor is running,
Turn on the lights , one at a time.
Posted on Jul 30, 2012
Is 147 Amperage ton much at rec
I don't understand your question. Are you asking if 147 VOLTS is too much at the receptacle? If so, yes - that's too much. Are you asking if 147 amps is too much to expect from your generator? If so, yes, that's far too much.
Jul 18, 2014 | Watts Onan Portable Generator - 5000 ,...
Northstar 6500 generator oil pressure switch wiring
Need to look at what your talking about, too many possibilities.
Jan 18, 2013 | Northstar Generator 10 Hp, 6500 Watt,...
What's the mag or coiul on a generac 6500 generator 13 hp
The "mag" is a magneto and it generates the high voltage pulse to fire the spark plug. The "coil" is about the same thing but it uses a set of points or an electronic ignition to control when the spark is delivered.
Sep 30, 2012 | Generac 6500 Watt Gasoline Generator - 49...
Alternately,
May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan 6.5nh manual download
Right here you go. www.cumminsonan.com/www/pdf/specsheets/a-1509.pdf
Feb 17, 2010 | Watts Onan Portable Generator - 5000 ,...
Aug 23, 2009 | Electrical Supplies
I have a 6500 es that keeps blowing the 15 amp fuses. It will sometimes run 1 hour or maybe even 2, but then it blows the fuses. What could be the problem.
What are you pluging into the generator??? If the the item/s are drawing more amps or watts, than the 6500 will handel, EX: 6500+or++ or if you add something while it is running, ka pow! Please let me know specifically what you have pluged into it, the fuse only blows if you are overloading it! Check the amp or watt draw of what you are pluging into it to see if the generator can handle it. If you overload the generator enought times you can burn the windings and than it gets costly. Talk to your local shop about what it can handle.
Jul 18, 2009 | Honda Electrical Supplies
Onan 6500 male 120/240 plug
Northern Tool has a hundred plugs/recepticles. you need to know the amps and volts. just match them to the pictures. or email them a pic of what you need. they helped 3 of my customers with the issue. hope that helps...good luck...
May 28, 2009 | Watts Onan Portable Generator - 5000 ,...
Electronics - Others Logo
107 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
