Question about Zenith H27G48S TV
Disconnect A/V jacks message appears
The above message appears anytime I try to change the channel. I have noticed that the front A/V jacks are loose and wondered if there was a way to disable them so that the T.V. will work properly again. Thanks for your time. Brad
  • kovalex_84 Apr 03, 2009
    I just had the same problem and thats why i search the message error. Guess what made it work? i just touched "Video In" jack and unplugged my ethernet cable from the wall, i dont know if it has to do anything with it, but it started working. :)) good luck
THE CIRCUIT TRACES ARE BROKEN ON THE JACK CBA. REPLACE RCA JACK CBA.
Posted on Oct 06, 2008
  • 3 Answers
In the service menu option 40 ( auto camport ) should be set to 0 not 1
Posted on May 01, 2008
SOURCE:
How do I turn off pscan on a rca dro2oon DVD player
IMPORTANT:
If you don't have a Progressive Scan TV or you don't have the DVD player connected to the correct Input Jacks, and you activate Progressive Scan in the DVD player you won't see a picture! Don't panic-try the following:
First, press the PREV/VIDEO button on the front of the DVD player (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If that doesn't work, press and hold PREV/VIDEO button on the front of the DVD player for 3 seconds. Now, press the PREV/VIDEO button again (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If you still don't see a picture on your TV screen, make sure the yellow cable (provided) that is attached to white and red cable (called audio/video cables) is connected to the DVD player's PREV/VIDEO jack and the TV's Video Input jack. Change your TV channel to your TV's Video Input
channel that activates the TV's VIdeo Input jack where you have connected the yellow cable (page 9 of your manual has more information).This PREV/VIDEO jack on the DVD player always outputs interlace video, so you should see a picture on the TV screen.
As a last resort, you can reset the DVD player to the factory default settings:
Press and hold the STOP button on the remote control and the NEXT button on the front of the player at the same time - wait at least 5 seconds before you release both buttons
Sep 25, 2016 | RCA Televison & Video
Can i connect juster speakers 675 to my dell laptop?
Plug the power transformer into the bottom jack on the back of the right-channel speaker. This is the speaker with the on/off knob on the front. 2 Plug the audio cable attached to the left-channel speaker into the audio jack on the back of the right-channel speaker. The jack is immediately above the jack for the power cord. 3 Plug the audio jack attached to the back of the right-channel speaker into the headphone jack on a laptop computer (usually located along the left edge), or to the audio output jack on the back of a desktop PC. 4 Plug the speaker transformer into a surge protector and the surge protector into a wall outlet. 5 Turn the on-off and volume control knob clockwise on the front of the right-channel Inspiron speaker to activate the stereo speakers and adjust the volume.
Aug 07, 2012 | Juster : SP-801 Twintower Speakers...
Sound delay when changing channel
Look for any loose contacts in RC jacks/sockets/Cable. Check your power outlet for any loose contacts. Try changing the input device to something you are sure, works such as a DVD player. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Vizio Gallevia GV42LF 42 in. LCD...
Using Ex Pat Shield, BBC progs no longer start and a notice, 'Task failed at step 0: config was empty.' (Or 'Task queue failed ditto' Everything worked fine just days ago.
I have exactly the same problem, same error message. I first noticed the problem yesterday (September 11). Error message appears when trying to watch live TV through iPlayer. BBC News Channel works OK from BBC News website. Live sports broadcasts work OK through BBC Sport website. I uninstalled and reinstalled Flash Player but it made no difference.
Sep 12, 2011 | AnchorFree Expat Shield
I just bought a used valveking 100 half stack and the 1st channel does not work, second channel works but seems to have a loose input jack as connection is intermittent and affected by wiggling the input...
Same thing... they probably broke both jacks. Sometimes the guts of the jack is broken and it doesn't appear to be broken but is broken internally. You may find broken solder on the pins to these jacks as well.
Note that the two input jacks have a different gain.
Here is schematic: http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
Dec 02, 2010 | Peavey Valveking Head
How do you remove the backing plate from an '05 Chev Venture rear hub so the hub can be replaced?
The 4 Bolts that Hold the HUB in Also Hold the Backing Plate
Hub Replacement - Rear (Front Wheel Drive/Drum)
Removal Procedure
  1. Raise and support the vehicle.
  2. Remove the tire and wheel.
  3. Remove the brake drum.
    1. Remove and DISCARD the wheel bearing/hub bolts.
    2. Remove the wheel bearing/hub.
    3. Disconnect the wheel speed sensor electrical connector (2).Installation Procedure
    4. Connect the wheel speed sensor electrical connector (2).
      1. Install the wheel bearing/hub. Caution: These fasteners MUST be replaced with new fasteners anytime they become loose or are removed. Failure to replace these fasteners after they become loose or are removed may cause loss of vehicle control and personal injury. Notice: Refer to Fastener Notice in Service Precautions.
      2. Install the NEW wheel bearing/hub bolts.
      1. Install the brake drum.
      2. Install the tire and wheel.
      3. Lower the vehicle.
Nov 07, 2009 | 2005 Chevrolet Venture
Computer turns on leaves message and cuts off
this means that your cpu fan is facing some problems so its better change it or else your pc will encountered on and off. you can use it for 2-5 minutes then turned off automatically and you will notice the the lights is still on.
Oct 07, 2009 | HP M490N PC Desktop
Reception/ jacks on the back of a SHARP L32 - X200 Cinema select
go to VCR, OR DVD player. Use channel selection there.
Dec 07, 2008 | Sharp 32L-X2000 32" TV
Zenith H27G48S TV Logo
750 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
