Question about Sylvania SilverStar Halogen Sealed Beam - H6024 ST
H6024 pinout - Sylvania SilverStar Halogen Sealed Beam - H6024 ST
I need the pinouts for a nintendo wii headset (usb pinouts)
The USB interface is standardized. Knowing the pinouts isn't useful for creating your own headset, but here are the pinouts anyway:
http://pinouts.ru/Slots/usb_pinout.shtml
Feb 03, 2013 | Nintendo Wii Console
Connecting usb
Usually red white green and black unless the motherboard has a cable connect lead already
The USB Pinout:
Pin
Name
Cable color
Description
VCC
Red
+5 VDC
D-
White
Data -
D+
Green
Data +
GND
Black
Ground
http://pinouts.ru/SerialPortsCables/usb_cable_pinout.shtml
http://pinouts.ru/Slots/USB_pinout.shtml
http://pinouts.ru/connector/4_pin_USB_A__USB_B__mini-USB_jack_connector.shtml
hope some of these will help you
Feb 24, 2012 | Foxconn 6100K8MA-RS Motherboard
Pinouts power supply for hp d530 ultraslim
Hi lantzgema,
I looked up the specs of your d530 and all I could find out is that you have a 150 power supply, calling HP technical support was no help at all.
I did find some pinouts you can look at and determine which one exactly you have. Hope this help out.
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm
http://pcsupport.about.com/od/insidethepc/a/sata-pinout-15-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/molex-pinout-4-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-4-pin-12v-psu.htm
If this is still not what you have there are other pinouts at the same website.
Dec 28, 2010 | Computers & Internet
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
VGA connector on a Dell e770s 17 inch monitor has been cut. Need to know where the wires go on a 15 pin db connector?? Can anyone help...Thanks gvp
Found out the information thru this page. Its a diagram of the 15 pin VGA Pinout and where the pins are supposed to go and what there fuctions are, hope this helps. Page is courtesy of pinouts.ru
http://pinouts.ru/Video/VGA15_pinout.shtml
Aug 29, 2009 | Computers & Internet
Cable end chopped off need to know pinout mapping to reattach a new cable end to attach to computer.
All VGA connectors use the same pinout. Here's a link that shows you the VGA Pinout,
http://www.interfacebus.com/Design_VGA_PinOuts.html
More monitor pinouts,
http://www.montest.com/technote.html
Apr 21, 2009 | KDS K717s 17" LCD Monitor
Sylvania SilverStar Halogen Sealed Beam - H6024 ST Logo
60 people viewed this question
Top Sylvania Electronics - Others Experts
Are you a Sylvania Electronics - Other Expert? Answer questions, earn points and help others
