Question about Sparco Tabletop Folding Machine, Letter Size, 14-1/4 x 6 x 14 Inches,
It is not folding the paper correctly - Sparco Tabletop Folding Machine, Letter Size, 14-1/4 x 6 x 14 Inches,
What are the different types of folds that a paper folding machine can do?
There a few different types of folds that a paper folder can do. All the different kinds of folds can be found on this site. Before you get excited about all the different folding options that are available you want to make sure that your folding machine is capable of doing those folds.
Sep 24, 2013 | Office Equipment & Supplies
Can a paper folding machine fold paper of different sizes or do they only work with standard size paper?
Most higher end folding machines are able to fold most standard size sheets of paper. You would have to check the manual or with the maker before trying anything too fancy. Mine works great with A4 and standard 8.5 x 11" papers.
What is a paper folding machine?
This is a machine that folds papers or letters instead of you folding them all by hand. It can fold statements, invoices, brochures, etc. It's really useful for businesses. It can fold about 1800-18000 papers in a single hour.
Jan 17, 2013 | Office Equipment & Supplies
I cant print on white vellum paper on my epson stylus nx420 i need to print some invitations and it is just folding my paper
Try placing some standard paper behind the vellum paper, it might assist in holding correctly while printing.
Being so thin the paper I would guess is folding up under the print head? if so look through all the printer properties, under the maintenance section there may be a "set Plattern Gap" (set to wide) or "Thick Paper Setting"
Selecting these raises the print head up to allow for thicker paper to pass through, but can also help thinner paper from folding up under the heads.
I hope one of these works for you.
Regards GM
Apr 12, 2011 | Epson Stylus NX400 InkJet Printer
Brother 2040 paper light .. continuous red
If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
May 03, 2017 | Brother HL-2040 Laser Printer
HP laserjet 4350 DTN Folding corners
teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Oct 09, 2008 | HP LaserJet 4350dtn Printer
Paper fold
when you use the by-pass it's ok. when using tray paper z folds.
1- change feed & sep tires ( timing off)
2- bad seperation, roller or seperation assembly is bad or needs adjustments ( adjust in service mode or change)
Jun 20, 2008 | Canon imageRUNNER 400S Copier
Register tape
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle. Looks like >
Then, place the paper into the slot where the paper feeds into in the back. (Paper will get fed under the printer assembly) and then hit the PAPER FEED/ADVANCE button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Feb 13, 2008 | Sharp EL-2192Rll Calculator
Martin Yale Paper Folder Problem
Im not familiar with a paper folder but if its anything like a printer, it probably has a maintenance kit you can buy or you may have to replace the rollers. Alot of the times they have a rubber grabber that wears out or a roller that gets dirty and doesnt catch the paper evenly and pulls it through at an angle, crinkling it. Check for debree or paper particles that may be floating around inside.
Jan 02, 2008 | Computers & Internet
Sparco Tabletop Folding Machine, Letter Size, 14-1/4 x 6 x 14 Inches, Logo
82 people viewed this question
Top Sparco Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Sparco Office Equipment and Supply Expert? Answer questions, earn points and help others
