Question about DCS RGS-486GD Gas Kitchen Range
Igniter does not stop sparking, burner select
Igniter does not stop sparking, burner select knob light(blue) stays on, with the burner knob selected off. Only right rear burner affected, but must pop the c/b to stop the igniter sequence.
SOURCE: electric igniter does not stop sparking after the
On my DSC RGT-305 range it wasn't either the spark module or the wiring, it was one of the little rotary switches that sit behind the burner control knobs. It shorted out (verified with an ohm meter). The switch is made by State Tool & Mfg. Co. and the part number is 25300. Wayne
Posted on Dec 01, 2009
heatman101
  • 43501 Answers
SOURCE: igniter keeps clicking after burner lights
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Aug 31, 2010
SOURCE: igniter will not shut off on my DCS RGS-366 gas range
Replace the multipoint gas re-igniter, it is a blue unit behind the knobs. This unit detects the flame and stops the clicking. Call Fisher and Paykel (owners of DCS) at 1 888 936-7872, they sell parts for DCS. The old inferior unit is blue and has a whte label. The newer unit has a yellow label.
Posted on Nov 11, 2010
SOURCE: oven wont light ,igniter is
Ignitor is the most common problem, even when it appears to be glowing somewhat. If you've already replaced it, then it's the gas valve. Call for service!
Range repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
Posted on Jan 26, 2011
  • 747 Answers
SOURCE: igniter wont stop nclicking after burner turns on
your botton on your igniter went bad.
Posted on Feb 05, 2011
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Burners light but ignition keeps clicking
use a blow drier to dry the igniter and knobs.
May 21, 2014 | Jenn-Air Kitchen Ranges
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
CONSTANTLY SPARKING
ONCE BURNERS HAVE LITE TURN THE BURNER KNOB BACK THE OPPOSITE WAY A LITTLE BIT AND SEE IF THR IGNITER QUITS SPARKING, HOPE THIS HELPS.
Oct 22, 2008 | Frigidaire FGF316 Gas Kitchen Range
Igniter will not shut off on my DCS RGS-366 gas range
Jul 23, 2008 | DCS RGS-366 Professional Gas Kitchen Range
Igniter problem
After the burner lights move the knob a fraction away from the lite position.
If that fails, replace the spark ignitor switches on each gas valve.
Jun 24, 2008 | Whirlpool SF325 Gas Kitchen Range
Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Jun 01, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Igniter
It is normal for all 4 burners to spark at same time.  Often burners won't light even when you can see the spark at them because the burner is dirty.  Take a pin and clean out all the holes in rim of burner.  Also look for small cracks in white part of igniter.  If cracked it must be replaced.
Oct 21, 2007 | Kitchen Ranges
DCS RGS-486GD Gas Kitchen Range Logo
21 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
