Question about Makita MAC2400 Electric Powered Air Compressors
Will not hold pressure - Makita MAC2400 Electric Powered Air Compressors
Force 120, 1999, no start cold, stalls out after running for 10 min, cranks hard restarts after sitting few minutes. Think fuel pump, any mercy mechanics out there that can give me a hand with this
Don't know this car. Check fuel pressure with a fuel pressure gauge- if correct, not a problem with the pump. Also make sure the pressure will hold for some time with key off. It should hold pressure for several minutes, maybe 20 minutes, some maybe a bit less, but it must hold pressure for a time. If pressure is good, check for spark when it won't restart. If spark is lost, suspect the crank position sensor.
May 25, 2017 | Cars & Trucks
How do you reset the low tire pressure light?
To reset the tire pressure system, do the following:
(NOTE!....Do not reset the check tire pressure system without first
correcting the cause of the problem and checking
and adjusting the pressure in all four tires. If you reset
the system when the tire pressures are incorrect,
the check tire pressure system will not work properly
and may not alert you when a tire is low or high.)
1. With the engine off, turn the ignition to ON.
2. Press the MODE button until the DIC reads LOW
TIRE PRESSURE HOLD SET TO RESET.
3. Press and hold the SET button until you hear a
chime, and TIRE PRESSURE RESET is displayed.
You will hear three chimes, then the LOW TIRE
PRESSURE message will go off and the DIC will return
to TIRE PRESSURE NORMAL. If the LOW TIRE
PRESSURE message comes back on, the check tire
pressure system has not reset. Repeat the procedure.
The system completes the calibration process during
driving. The system learns the pressure at each tire
throughout the operating speed range of your vehicle.
The system normally takes between 30 and 60 minutes of
driving to learn the tire pressures. The system normally
takes 10 to 20 minutes of driving in each speed range to
learn tire pressures. The speed ranges are 20 to 40 mph
(32 to 64 km/h), 40 to 60 mph (64 to 96 km/h), and above
60 mph (96 km/h). This time may be longer depending on
your individual driving habits. The learning process does
not need to be completed during a single trip. Once
learned, the system will remember the tire pressure until
the system is reset.
Jun 02, 2014 | 2004 Buick Rendezvous
Bled clutch no pressure why
close bleeder pump clutch 3 or 4 times hold clutch in open bleeder close bleeder pump clutch lever 3 to 4 times hold clutch in open bleeder fluid will start to squirt out under pressure close bleeder let clutch lever out pump 3-4 times repeat untill you get pressure in lever hold lever while bleeding donot release while the bleeder is open
Apr 26, 2014 | 2000 Suzuki VL 1500 Intruder LC
Coolant system holding pressure
Holding pressure is a good thing. When it doesn't hold pressure worry. The cooling system Is a close system and when the coolant gets hot it actually expands creating pressure. Once it reaches a certain temperature the thermostat opens allowing hot coolant back into the radiator to cool and if there is to much pressure in the radiator a valve on the cap allows the coolant into the reservoir. When hot there's pressure which is why you should never open a cooling system when hot.
Apr 17, 2014 | Toyota 4Runner Cars & Trucks
Ford expedition stalls
Sounds like fuel pressure regulator faulty, not holding correct pressure in rail. Check fuel pressure before and after filter, attach fuel pressure tester to rail turn key on check pressure, does it hold? If it doesn't regulator is bad.
Feb 24, 2014 | Cars & Trucks
My water pressure does not hold the pressure when i pull the trigger
does it hold pressure at idle? (trigger released) and then hold a lower pressure with trigger pressed? If so you probably have worn or wrong size nozzle
Jan 16, 2013 | Garden
2004 jeep code 1763 what to do
P1763 - Governor Pressure Sensor Voltage Too High
This code is refer for the governor pressure sensor which is located in the valve body of the transmission. If getting power to the sensor and the wires are not open or shorted then the sensor will need to be replaced.
GOVERNOR SOLENOID AND PRESSURE SENSOR
REMOVAL
Hoist and support vehicle on safety stands.
Remove transmission fluid pan and filter.
Disengage wire connectors from pressure sensor and solenoid (see picture)
Remove screws holding pressure solenoid retainer to governor body.
Separate solenoid retainer from governor (see picture)
Pull solenoid from governor body
Pull pressure sensor from governor body.
Remove bolts holding governor body to valve body.
Separate governor body from valve body
Remove governor body gasket.
INSTALLATION
Before installing the pressure sensor and solenoid in the governor body, replace O-ring seals, clean the gasket surfaces and replace gasket.
Place gasket in position on back of governor body
Place governor body in position on valve body.
Install bolts to hold governor body to valve body.
Lubricate O-ring on pressure sensor with transmission fluid.
Align pressure sensor to bore in governor body.
Push pressure sensor into governor body.
Lubricate O-ring, on pressure solenoid, with transmission fluid.
Align pressure solenoid to bore in governor body
Push solenoid into governor body.
Place solenoid retainer in position on governor
Install screws to hold pressure solenoid retainer to governor body.
Engage wire connectors into pressure sensor and solenoid Install transmission fluid pan and (new) filter.
Lower vehicle and road test to verify repair.
1 - PRESSURE SOLENOID RETAINER
2 - GOVERNOR
1 - PRESSURE SENSOR
2 - PRESSURE SOLENOID
3 - GOVERNOR
Hope helps.
Sep 29, 2011 | 2004 Jeep Grand Cherokee
How do i reset flashing low tire pressure,change oil soon after the problem is taken care of?
To reset the tire pressure message, first make sure all pressures are appropriate, then turn the ignition on with the engine off. Press and hold the GAGES button located on the left side of the steering column until TIRE PRESSURE appears in the display. Press and hold the RESET button for 5 seconds until TIRE PRESSURE RESET appears then release the RESET button.
To reset change oil soon message, press GAGES button until OIL LIFE displays. Press and hold RESET for 5 seconds.
Mar 15, 2011 | 1998 Buick Park Avenue
Will not hold pressure. continous high pressure
is it possible to just tighten or add teflon to that fitting, just a suggestion, if tube nit cracked.
Aug 10, 2009 | Plumbing
Toyota rav4 1997 after i drive it about 1 hour it began to turnoff end difficul to start ,i wait 15 minutes after its ok
check fuel pressure possible fuel pressure regulator is going bad. fuel pressure should at 45 to 55 lbs.fuel pressure should hold for 5 min to 7 mins. if doesn't hold replace fuel pressure regulator
Jan 19, 2009 | 1991 Dodge Daytona
Makita MAC2400 Electric Powered Air Compressors Logo
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
