Question about Watches
My band on my invicta 6137 the black spacers part broke where do i get another one from
5 Suggested Answers
SOURCE: my Invicta pro diver watch
I would go to a watch repair shop and ask if the band can be fixed, DON'T ask if they can replace it, I don't know the extent of how bad it is broken, but alot of times it is something that can be repaired. If they say they can repair it try to find out (if you can ) what they would have to do to fix it. Then get back to me .
Posted on Aug 11, 2008
escapement
  • 2334 Answers
SOURCE: Invicta 2875 wrist watch band too large
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
  • 12 Answers
SOURCE: invicta mech.watch model 2625 lite brown leather
Invicta Service Center:
http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm
Posted on Jul 15, 2010
  • 12 Answers
SOURCE: My invicta stainless steel band has two bent
Contact Invicta for cost of repair:
Need a replacement band for Invicta Mens 4578
with the model number you should be able to find one easily on ebay or amazon. ask the seller any questions before purchase if unsure.
Mar 24, 2014 | Invicta Mens 4578 Russian Diver Collection...
I am looking for a new watch band for my Invicta Pop Lupah 2397 (turquoise). Where can I order one ? Julie
Visit the Invicta site. Their posted price list has prices for what I would expect is replacing the original watch band .
http://www.invictawatch.com/invicta/price_list
If you do not have a local delaer whom you can visit to onbtain a new watch band information on how to ship your watch to Invicata can be found here:
http://www.invictawatch.com/invicta/shipping
Mar 30, 2011 | Invicta Lupah POP 2397 Wrist Watch
Nesesito new band
Go to a jewelry shop that sells watches/watch accessories, or a watch kiosk at your local mall. Either of these places should have multiple bands that will work on your time piece. If you want a specific band (as in one identical to the one that came with your watch), you'll need to contact Invicta for that. Invicta Service Center
1 Invicta Way (3069 Taft St.)
Hollywood, Florida 33021
ph: (954)-921-2444
Jul 01, 2010 | Invicta ELITE 9225 Wrist Watch
Does my 2010 invicta corduba have pins or screws in the braclet? how do I remove them? They look like screws but juts spin around both way when i turn them.
Sometimes the split ends of pins look like screws. If the slot is extremely thin its a pin A screw slot will be a bit wider. I pin removal toll inserted into the smaller end should do the trick.
Apr 30, 2010 | Invicta Corduba Skeleton Techno Strap...
My invicta stainless steel band has two bent pins and I was told to send back to invicta repair. Is the repair of watch band more expensive than a new watch band and who can put on new band.
Most watch pins go for an average of 5 to 10 dollars per pin. If the band is in good condition there is no need to replace it. Most invicta metal bands can retail from 35 dollars and up. We are located in the Holyoke Mall in Holyoke MA
Apr 08, 2009 | Invicta Speedway 9223 Wrist Watch
Replacement band for the Invicta 2307
SORRY but FIXYA sells nothing .check with your dive shop
Aug 17, 2017 | Invicta Watches
My Invicta pro diver watch model #9204 band broke where can i get a replacement band for cheap
Aug 11, 2008 | Invicta Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
