Question about D-Link DIR-600 Router
Wlan light off
My router was working well. Suddenly it stpped and all the lights went off apart from the power light. I cannot now access the Router. What could be the problem?
  • 7,482 Answers
Hi Jimmy
Check your power supply, sometimes a failure in them causes this problem.
If your power supply is ok then the router has failed.
Replace the router.
Or maybe your internet provider has a problem delivering the internet to you, if that is the problem then contact your internet provider.
Bud
Posted on Oct 22, 2013
babb
  • 104 Answers
SOURCE: router not working, help please!
You may may need to configure your D-Link to use your type of internet! Try following the Quick Install Guide which can be found here: ftp://ftp.dlink.com/Gateway/di524/Manual/DI-524_manual_06292005.zip The WLAN light doesn't come on probably because you have the wireless disabled, which can be re-enabled once in the configuration for the wireless(in the document mentioned above) If you are having any difficulty following the guide or have folloed the guid and still can't connect, please get back to me regards, babb
Posted on May 15, 2007
  • 101 Answers
SOURCE: All the wrong lights are on!
Hi Starfish,
Try unplugging the Dlink, wait 2 min, and plug it back in. If that work, on the back is a small hole, marked RESET. Using a pencil, or straightne out a large paperclip, press that the button inside gently. Hold it for 30 sec. Release and unplug the unit. Shut down the whole network. "Starting from the wall", power up the modem, wait 2 min, power up the Dlink, and power up your machine. Your Dlink should be at default now. Remember to reset you security, change the password, etc.
I have had to do this several times, sometimes unplugging the power, and plugging it back while holding the button. (Got 3 hand?) Also, there as one firmware update, which had a mistake, that set the router IP to 102.168.1.1, rather than 192.168.0.1.
Posted on Jan 10, 2008
  • 49 Answers
SOURCE: D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Posted on Jan 10, 2009
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
  • 1768 Answers
SOURCE: router has reset itself to jumpstart-p1 something
This may be a router at the what is call the "end-of -life and no longer serviceable.
You may have to go an get the latest router at your computer store.
Firmware may be obsolete for the connectivity.
Posted on Apr 26, 2010
Flashing WLAN LIGHT ON EDIMAX ROUTER
No, it means it cannot set up a Internet Connection.
Try Powering Off and On again, if not contact your Internet Supplier.
Jan 27, 2013 | Edimax WiFi 150Mbps ADSL2 Modem Router
I have a Linksys WRT54G2 Router, It Has Worked Fine For About A Year, And Just Suddenly It Has Problems, The WLaN Light Isn't On At All, The Power Light Is Just Blinking At A Steady Rate. I Can't Access...
Please make sure that Power, Internet and Wireless Light (or LAN light if trying to connect with Ethernet cable) is there on router if you are trying to connect it wireless .
And if only Power light is there only.Please try to power cycle the router ( turn off the router from power supply wait for a minute, plug the power supply back) and then again check the light status.
Even after this if same light status is there please try to reset the router ( there will be small pinhole button on the back side of router) just press it for 15 seconds and then release it.Wait for 2 mins and check the light status again.
It will fix your problem.
Please share the results.
Dec 09, 2010 | Linksys WRT54G2 Wireless Router
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
WLAN light not working, router not working
D-links, just die like this I have had two of them do exactly the same, so i would.t wonder if your has done exactly that too. They are pretty mass produced. You will have to get a new one.
Apr 23, 2010 | D-Link AirPlus DI-524 Wireless Router
The wlan light isnot lightind, and i cant configure
Is the power light solid on the router. Try to reset the router for 30 seconds. then unplug the power to the router and plug it back in, Wait for 1 minute and try to reconfigure the router. Click Here for step by step solutions.
Nov 16, 2009 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Can`t conect to the wifi
Try resetting the router and then see if the WLAN will lit up.Maybe it just disabled on the router. have you tried accessing the router's setup page to see?
Sep 08, 2009 | Zyxel P660HW-D1 Router
DI-524 version D router problems
you need to open the configuration of the router. Read the manual in order to access on configuration. Once you access .. you can manually configure the router, and set what do you want.
Jul 27, 2009 | D-Link AirPlus DI-524 Wireless Router
WLAN light on WRT45G
Hi ,
it will continuously blink . this shows the siganl is transmitting from the access point. and this frequency of this light blinking will increase when some client computers are connected to your access point or router
Mar 31, 2009 | Linksys Wireless-G WRT54G Router
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
http://portforward.com/english/routers/wireless/Siemens/Gigaset-SE587/wireless.htm
May 04, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
D-Link DIR-600 Router Logo
49 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
