Question about Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet
How to change my proscan tablet ip address - Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet
10 rca tablet keeps losing connection have to shut down to get it to connect
Try setting it to a static IP address.
open router settings (type your routers ip address in web browser I.e.192.168.1.1)the admin name and password are normally on the router)then lan settings
set the MAC address of tablet as static noting the IP address (192.168.1.4 for example),subnet mask (normally something like 255,255,255,0),etc.( to find your tablets MAC address settings then about)
when you have set the router up, on tablet tap the settings then wifi, modifiy settings tick use static scroll down and enter new ip address ,subnet mask default gateway(your routers in address).
its easy then it looks.
Sep 13, 2017 | Tablets & eReaders
What is the Mac address and the ip address for nextbook. 7"tablet model #Next 7P12-8G
Every device has a different MAC address. Usually it will be found either on the back of the unit, on the box, or you can check the network settings, The IP address will change depending on the network you connect to in most cases as the standard settings are typically DHCP which means the computer gets the address from a server on the network. If you check in settings you should be able to see it,
Aug 14, 2015 | Tablets & eReaders
I have the digiland tablet dl700d(c) and I can't connect to Wi-Fi I called Wi-Fi support they can't help because the mac address keeps changing is anyone else having this problem and what do I do
Hi
I find your question very interesting, and also your WiFi support comment, because in 18 years of IT consultancy and troubleshooting I have never come across a changing mac address.
The mac address is
"a unique identifier assigned to network interfaces for communications on the physical network segment. MAC addresses are used as a network address for most IEEE 802 network technologies, including Ethernet and WiFi."
The emphasis here is on "unique" and all network adaptors I have come across - ethernet or WiFi have had a fixed mac address. Are you sure they didn't mean IP address, as this is supplied by the router/access point via a DHCP server, and can change according to the access requirements of the router/access point.
If you go here:
MAC address Wikipedia the free encyclopedia
you can learn a lot more about mac addresses.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | Tablets & eReaders
How can I get a IP address for my motorola table
You get an IP address whenever you connect to a WiFi Hotspot. Is there someting that you are trying to do?
Oct 28, 2014 | Tablets & eReaders
Why can I not get WI FI on my tablet? I have tried everything I can think of
With very little information it could be a number of things. Did you connect to it with a passcode? Assure your router settings are set for upnp enabled. Also, sometimes its best to give your tablet a fixed IP address rather than a dynamic one. There are free network scanner apps for tablets that will scan your network. Find out the current IP address and imput that into your DHCP reservation in your router administration. That way your tablet IP never changes. Part of your problem is i believe you have a dynamic IP set for your tablet and UPnP disabled.
Aug 24, 2014 | Tablets & eReaders
Obtaining IP address
You can obtain your tablet IP address from IP-Details.com .
Dec 01, 2013 | Archos 97 carbon 16GB 9.7" Capacitive...
Renew ip address
To renew your IP address in Tablet:
Remove the SIM card and then insert it (or) reset the WiFi if it is a Dynamic IP address it will get change.
Before and after changing check the internet IP address from the site IP-Details.com .
Jun 30, 2013 | Tablets & eReaders
The tablet cant find the i.p address for my internet
To know your network(internet) IP address from your Tablet visit the site Ip-Details.com . Here they also display the results such as IP location, ISP address, etc...
Feb 13, 2013 | Coby Kyros 716829701508 Tablet PC
Wifi will not connect on proscan tablet
This is not a helpful site so I wolud suggest you go to another website cause i have a android tablet and they didn't say nonthing about that all they said was something about a ipad aint no body got time for that. ps.go to another website if you got an android tablet
Nov 05, 2012 | Tablets & eReaders
Tablet can't locate ip address
You can follow the user manual guide of your tablet and locate the ip address in your tablet.Then visit the site Ip-details.com here it display ISP, IP location,Country and so on...
Jul 06, 2012 | Tablets & eReaders
Proscan Recertified - PLT7035 4GB NAND Flash 7" Tablet Logo
Top Proscan Tablets & eReaders Experts
tosin_christ
David Payne
David Payne
EE Eddie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
