Question about Fujitsu Siemens Computers & Internet
Amilo m52228 hdd
Have i can to turn on my alimo m52228 wireless?
Network Key (WEP, WPA, WPA2 Encryption key) To connect your computer to your wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 07, 2012 | Fujitsu AMILO Li 2727 Notebook
Remove hard drive amilo d7830
there's a cover marked with a little symbol that looks like a a cylinder remove the 3 screws and pull out the hdd it may be in a carriage in which case there will be more than likely 4 screws 2 on either side slide the new drive in and assembly is the reverse of removal
Dec 03, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Amilo d-7820... Sound driver failing install.
Bad, or obsolete, driver. Uninstall the one you have now and get (as in Save, not Run) the latest version directly from Fujitsu.
Oct 18, 2009 | Fujitsu AMILO D-7820 Notebook
Need to take my fujitsu amilo 1705 apart .
Alryt Mate.. i had exacly the same laptop.. and i had to take mine apart. dont do it ur self... take it to PC World or where u got it from. Once mine was took apart everything u touched just resarted the laptop.
Apr 21, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Cant install driver for ati on amilo d7800 missing exe/dll
Download the drivers again from Display - ATI MOBILITY RADEON (M6P)
Click I accept conditions on the download page to enable the download.
Mar 13, 2009 | Fujitsu AMILO PC Laptops
HI! Yes you can upgrade your Hard drive from a 30GB (std size) to as much as 120GB. The only thing yu need to be sure of is that you need to buy a IDE 2.5" HDD which is a little bit hard to find but is still available. Try to google some suppliers online.
Hope this Helps.
May 20, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu Siemens Amilo d7830 hard drive
Yes, you can up to 120 GB IDE 2.5" HDD. You can buy it from any PC store near you ar order online.
Hope this Helps.
May 08, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Amilo L7310GW will not boot up
Can you try switching on without the wireless mini pci card . but exercise care while disconnecting the thin two wires named MAIN & AUX from WLAN card .It is easy to remove this and you dont have to disassemble the entire notebook for this
Apr 23, 2008 | HP Pavilion dv6000z Notebook
Fujitsu Siemens Amilo D 1845
Hi!
I already locate and remove HDD of Acer and Toshiba laptops. And in my observation, almost all laptops have their HDD located at the bottom.
To be sure of this, turn and look at the bottom of your laptop, then if you can notice a somewhat sliced plate, with around
2 1/2 inch by 3 1/2 inch size, attached with visible screws, then try to open it. And as you did, you will find the HDD there. (that is if you already seen a HDD in a market without case. Cause familiarity can confirm it to you. And sometimes it is enclosed by metal plates.
Dec 13, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Amilo D 7820
Om die HDD te verander jy moet die cd-Rom uithaal (trek die clip met a pic van a lock na oop toe) en dan kan jy die cd-Rom uithaal. As jy dit doen dan kan jy die HDD sien. Vat die 4 screws uit en trek hom stadig uit. Moenie vergeet om die nuwe HDD op "master " te sit.
Oct 16, 2007 | Fujitsu AMILO D-7820 Notebook
Computers & Internet Logo
79 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
