Question about Electrolux Guardian Bagged Canister Vacuum
Electrolux Renaissance c104a Wiring?
What is the correct wiring for the hose at base of machine. There are four pins. Two are Yellow. Two are black.
  • 15 Answers
SOURCE: RENAISSANCE HOSE/VAC
THE RENAISSANCE IS KNOWN FOR HAVING PROBLEMS WITH THE CIRCUIT BOARD IN THE HANDLE.YOU'LL NOTICE THAT MODELS THAT CAME AFTER THAT HAD SLIDING SWITCHES. UNFORTUNATELY THE NEW HOSE DESIGN WON'T WORK ON YOUR MACHINE BECAUSE THE CIRCUIT BOARD INSIDE THE MACHINE WAS CHANGED TOO.AERUS MAY OR MAY NOT STILL MAKE THE PARTS YOU NEED. OTHER WISE LOOK ON E-BAY FOR A NEW HOSE.
ELECTROLUX FOOLISHLY REPLACED IT'S FLAGSHIP STEEL MACHINE WITH THIS DESIGN...A FEW YEARS LATER ALL THEY HAD WORTH SELLING WAS THEIR NAME, HENCE THE NEW NAME AERUS.
Posted on Apr 10, 2008
  • 140 Answers
SOURCE: Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
Posted on Dec 31, 2008
  • 70 Answers
SOURCE: Renaissance C104A does not turn on.
The Renny is a hard machine to diagnose. You could have a broken wire in the cord or in the hose. There is a fuse wire located inside the canister that could be bad.Also, the handle circuit board could be bad or the triac (another circuit board) located inside the canister could be bad. There is no use for you to open the machine. You could do more damage than good.
Posted on Jul 15, 2009
  • 70 Answers
SOURCE: I need a service manual for an Electrolux C104A
If you talking about the part that swivels it is called the elbow and the part number is 46861.
Posted on Jul 17, 2009
  • 70 Answers
SOURCE: Electrolux C104A does not turn on. won't start. No
The Renny is a hard machine to diagnose. You could have a broken wire in the cord or in the hose. There is a fuse wire located inside the canister that could be bad.Also, the handle circuit board2.gif could be bad or the triac (another circuit board) located inside the canister could be bad. There is no use for you to open the machine. You could do more damage than good.
Help me troubleshoot Epic 8000!
Try a different hose to test the motor. Make sure it's a good one from a working vacuum. If it works, the problem is likely in the switch, wiring, but could be the hose itself. Other problems could the the triac or relay in the vacuum.
Best thing to do is to take it in to an Aerus dealer and let them troubleshoot it if a different hose doesn't work.
Note: Do NOT use a Renaissance hose.
Jun 14, 2015 | Electrolux Vacuums
Electrolux Vacuum Renaissance Power head brush won't turn
if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
give the hose itself a good look over sometimes the wires up by the grip break in the casing
Mar 12, 2014 | Electrolux Vacuums
I have a Renassiance C104A and once you plug it into the wall socket, it starts to run and no lights are on the handle....I've replaced the circuit board in the handle and the triac inside the...
There are a lot of things that could cause this problem because the wire runs through the hose. There is a connection on both ends you should check to make sure they are clean.
With the machine running try to "wiggle" the hose connections to see if the head gets power intermittently
Oct 16, 2013 | Electrolux Guardian Bagged Canister Vacuum
Electrolux canister C104A: Unit shuts itself off and LED in handle next to OFF button flashes.
I have a similiar problem, but LED light does not flash. I have determined it is a short in the hose wire. THERE ARE NO REPLACEMENT PARTS FOR THIS MODEL OF ELECTROLUX. I'll never buy another Electrolux product.
Oct 31, 2010 | Electrolux Guardian Bagged Canister Vacuum
LUX RENAISSANCE WONT TURN ON. HOSE CONTROL BAG LIGHT IS ON
Could be the board in the handle but I found that a lot of the times the contacts where the handle meets the hose just need to be cleaned. It could also be a clogged hose but I'd say it's one of the other two.
Dec 04, 2009 | Electrolux Vacuums
Electrolux C104A does not turn on. won't start. No light on, no sound. Is there any fuse to be raplace and/or ?
Jul 06, 2009 | Electrolux Guardian Bagged Canister Vacuum
Renaissance C104A does not turn on. I plugged it in and it does not work.
Electrolux renaissance power hose
If the wires power a motor then it shouldn't actually matter as the motor is AC which has no polarity.
Oct 07, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
77 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
