My Acer TimelineX model 5830T gives a "No bootable device" message. It makes it seem that the hard drive is going bad, but when I remove it an put in an external sata device, the drive works without error. I put it back in the laptop and get the same message. I then have to put pressure above the keypad and hold it down while powering on the system and it boots up. I've had this problem before and sent it in to Acer for out of warranty service for approximately $199 with a 90-day warranty. Almost 1 year later, the same problem occurs. It's not the hard drive. Have you seen this problem before? Is there a fix without having to send it to Acer?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 183 Answers
It could be either the hard drive cable which could be loose or the hd controller . the pressing points toward loose/bad cable
Posted on Oct 30, 2013
  • 111 Answers
SOURCE: IBM 300PL Model: 6862-V20 Booting Sequence cleared problem
boot in bios and reset the intrusion to read and clear it out alot of times the bios will use its backup when cleared clear the ir setting as weel and remove any passwords in the security setting in the bios if you are using a pov card you may have to take it and reset the machine then disable the card funtion reinstall then reset the card from there
Posted on Dec 19, 2008
renosean
  • 492 Answers
SOURCE: What software program will clone to an external drive?
It is nearly impossible to boot from external hard drive.  The main reason it that typically the computer need to have the OS loaded in order to support the external HD on the usb system.  My recommendation would be to return the external, purchase and internal and have a professional migrate your drive to the new one.
Posted on Jan 06, 2009
  • 16 Answers
SOURCE: IBM Thinkpad A20m model 2628
You can download the software known as Active boot disk. With this you can create a bootable cd to run a chkdsk with the f and r command to fix and recover errors on disk. you can also explore your comp and copy files to an external disk. If after the system boots normally after chkdsk you might have a problem with your HDD get it replaced before it crashes again
Posted on Jan 26, 2009
rajak2009
  • 527 Answers
SOURCE: cloned hard drive wont boot up
sir,
Check with bios settings. also check the cable if sata activate at bios. need to check bios itself.
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Mar 24, 2009
efs_perpends
  • 1996 Answers
SOURCE: WinXP Won't boot after installing a second hard drive
I'm guessing maybe the IDE cables aren't connected properly, or the jumpers need to be set for cable select. Are you sure you configured the jumpers correctly for the master/slave setting for that particular drive?
Then again, when you enter the bios setup at boot does it recognize the second drive, but xp fails to boot, or is the bios also failing to recognize the 2nd drive? If that's the case, and the bios is set correctly, your drive may be at fault.
Check your bios setup,
If all that's in order, all I can offer is a couple links that might help you to sort it out.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
regarding partitioning, http://www.theeldergeek.com/hard_drives_09.htm
And here's a link to a bios primer, that may shed some light on your situation.
http://www.pcguide.com/ref/hdd/bios/index.htm
I hope this steers you in the right direction. Let me know if you get it sorted out...
Posted on Mar 26, 2009
If you starts it, there is black screen with the message: media test failure
Go into the BIOS settings at boot up. Disable the option to boot from network, that must solve it :)
May 27, 2014 | Acer Aspire 5100 Notebook
Acer timelinex 5830t laptop batterij
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 30, 2012 | Computers & Internet
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Jan 10, 2012 | Acer Computers & Internet
Acer aspire will not start. get message check cable connection! PXE-E63 error while initializing the NIC PXE-M0f Exiting Intel PXE ROM No bootable device - insert boot disk and press any key. Netbook has...
1. It seems that the hard drive is not bieng detected by the computer 2. and from the error message that you are getting it seemed like windows is not loading up 3. I would suggest that you take out the hard drive and put it back in 4. the reason for that is the hard drive that connects from the mainboard is
May 29, 2011 | Computers & Internet
My daughter's ACER inspire one gives the following message and makes a beeping sound "Check Cable connection! PXE-MOF: Exiting Intel PXE Rom No bootable device---insert boot disk and press any key
There is a loose connection between the hard drive and motherboard of the computer, that's why you are getting that message. You most likely need to take it to a computer repair shop so they can fix it.
Mar 06, 2011 | Acer Aspire One PC Notebook
Computer will nt start and gives this message: no bootable device - insert boot disk and press any key.
Hello Sir, hi, try removing all usb devices on your Aspire, and then boot again, if the problem still persist, go to bios setup and look and see if the hard drive is present, if yes you need to setup windows again. The ASPIRE one later models now comes with a 120 GB hard drive but has an SD card/Flash module for a hard drive as well.
Jan 03, 2011 | Acer Aspire One PC Notebook
I have put windows 7 onto my acer and i want to put vista back on using my acer disc, the message reeds no bootable device
Have you made the CD/DVD drive the first bootable device?
When you installed windows 7, did you delete the ACER recovery partition on your hard drive.
If this has been deleted, you may need a full copy of windows, not just a restore disc.
Where you having problems with windows 7?
I have found 7 to be far superior to vista
Aug 13, 2010 | Computers & Internet
My acer aspire one says no bootable device
This sounds awful, but a friend just had the same problem - no bootable device. He had dropped it, hitting keyboard first. Now he thumped it on the opposite side and IT WORKED! Must have been a loose connector
Jun 03, 2009 | Acer Aspire 4315 Notebook
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
