Question about Ovens
Belling farmhouse 900G manual - Ovens
Belling service manual
I have one I have scanned and photocopied - will be listing it on ebay soon, so save a search and you will be alerted when I list it.
Aug 18, 2014 | Belling Ovens
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
I have a belling farmhouse range cooker but the gas mark numbers have faded so when the oven is switched on we don't know what temp it is on. Is there any way of fixing this?
Set the marker to the level as it is and measure the temperature with a thermometer. Now use a good marker and etch it on the metal body repeat it higher and lower with a gap of say 25 degrees. Have a marking on the knob set in place and now you have made a new calibration to the oven.
Use paint.sticker or anymedium to mark it properly .
Hope my advice helps.
Aug 28, 2010 | Ovens
Cooker problem
If it has a timer, make sure it is set to manual or it will not heat, another possibility is a faulty thermostat, you need to find out if you are getting power to the element, if you are then element should work unless you have got a faulty one.
Plz rate this solution.
Dec 15, 2008 | Belling Ovens
Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Ovens Logo
73 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
