Amana apn12hj my amana apn12hj has a red light bucket full on the front panel. what do I need to do?
4 Suggested Answers
BarrettDenCo
  • 1772 Answers
SOURCE: not sure if i need to vent my amana air
Sorry to read about your problem, I hope this helps you out.
No need to vent, as this is a electric unit, no gas
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 30, 2010
Testimonial: "Thank you for the very quick and helpful response "
hvac1960
  • 2133 Answers
SOURCE: my amana apn12hj is not blowing out heat? Not
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Posted on Dec 31, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: bucket full light is on, I have drain tube out the window, air won't work. How to fix?
    Hi Kathleen King - Typically when the error code P1 displays on panel it indicates that the unit has a sensor error. I would recommend contacting a professional to accurately diagnose and repair the unit.
    Posted on Oct 04, 2012
    Red Lite is flashing, unit will not turn on
    if the red light is flashing this means theres a fault , most common fault on these are water catch bucket is full or not seated back correctly
    Aug 24, 2015 | Amana D950EP Dehumidifier
    Flashing light is on(power on/off pad)
    red lights on dehumidifiers almost always indicate a full water catch bucket , this does not allways mean it's actually full of water , the machine thinks it is , some thing has gone ary with the level sensor in bucket , these most times are a simple float switch, that can get knocked out of position when one is emptying the bucket , also this same float switch also allows machine to know there's a bucket in place to catch water , sometimes bucket is not in correct place to catch water so machine wont start
    May 26, 2015 | Amana D945E 45 Pint Capacity Dehumidifier
    The Bucket Sensor light is always beeping and the front panel says 01. The machine refuses to work
    Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
    Dehumidifier Problem It shows Bucket Full
    heatman101
    Sep 18, 2011 | Kenmore 54501 Dehumidifier
    Portable amana a/c 10,000 - btu ; keeps sounding like the water is dripping inside all the time....but no leakage...does this mean needs to be drained soon? or is this sound normal?
    That's the water dripping into the water collect bucket/tank, which is normal. The unit should turn off automatically, when the bucket becomes full and needs to be drained. There should be a warning light that will come on when the bucket is full.
    Hope this helped you and thanks for choosing FixYa.
    Jul 25, 2011 | Amana Heating & Cooling
    Why is the red water full light on and not worrking?
    Usually, when the red water full light glows, it means that the water collection bucket is full & needs to be removed and emptied. Once that's done and the bucket is reinstalled properly, the red light will go out and the unit will turn back ON.
    Jul 07, 2011 | Daewoo DHC-400 Dehumidifier
    My amana apn12hj is not blowing out heat? Not sure if i set it up properly?
    Dec 30, 2010 | Amana Heating & Cooling
    Not sure if i need to vent my amana air conditioner model apn12hj when i want to use it in heat mode
    3 Thumbs - Helpful
    Dec 30, 2010 | Amana Portable Air Conditioner
    GE dehumidifier light says bucket is full but it isn't
    Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
    Thanks - Tech101
    Jun 19, 2008 | Dehumidifiers
    Control panel lights up-nothing else happens
    first check that the bucket is in properly. then remove bucket and push red button with finger with the unit on. if you are still getting a red alarm light it might be time to change the control panel. also unit does not work the same in cold weather. it will cycle too often. unit better used in summer-------good luck
    Dec 16, 2007 | Kenmore 5365 Dehumidifier
    Heating & Cooling Logo
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
