Question about Aquacal HeatWave
Model 5302B - FLO light is on - can't adjust temp. and compressor mtr/fan not coming on?
How do i fix AC Dolcool split type, Model KF61G, compressor not working. Breaker keep tripping.
It sounds like compressor is shorted,check ohms from compressor terminals to copper,clean area on copper.if it reads ohms,short,if not I would start by disconnecting outdoor MTR,indoor MTR,& see if still tripping
May 07, 2015 | Refrigerators
My air conditioning will not turn on. The thermostat control has only four buttons,two adjusting the temp up or down,one turns the fan on or on auto and the other selects the system cool heat or off. When...
After setting the unit to cool and adjusting the temperature, the compressor should run if the light stops flashing. Check the condenser, if the fan and compressor does not run, check the contactor if it is energized or pulled in. If the contactor is not pulled in there must be no power or the holding coil is open. If the condenser fan is running without the compressor, check your compressor, high pressure switch, and capacitor.
Sep 09, 2011 | Honeywell Heating & Cooling
Heater Fan Motor stops working
fan mtr needs to be replaced. If you locate the mtr under dash on the passenger side or under hood. then wiggle wire connector or lightly tap on the mtr. if mtr. cuts on and off you have found the problem
Feb 16, 2011 | 2000 Oldsmobile Alero
Compressor fan mtr hot, hear it try to energize for approx 2 seconds then stops aproximately 1minute later cycle repeats, removed coil voltage and manually acuated coil did not hear anything trying to...
The motor bearings have siezed up and the motor needs to be replaced...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 22, 2010 | Goodman CPLE24-1 Air Conditioner
With the thermostate off the interior fan runs but when i turn the thermostat on it trips the breaker
Not good! The thermostat only supplies power to the compressor section, so a breaker tripping is a sign of a 'dead' short to that area. If lucky, it just an exposed wire or terminal connection damaged in that area, but rarely the cause. More likely is compressor mtr "locked rotor", or stuck "potential" start relay holding the mtr circuit in hi-amp load, or shorted internal motor winding's. The condensor fan can also short closed, but is rare due to it's design. I have to assume the electic breaker suppling that circuit is not failing, as cause?
Jul 09, 2010 | True TD-95-38-LT Beverage Cooler
Case lights and fan do not come on, ''H'' appears on digit readout
This sounds like a refrigeration problem. On most freezers there are temperature switches that control the interior fan and light. The fan and light will not come on until the temp switch senses that the evaporator coil is at freezing or below. The "h" is a "high temp warning I would gues. :)
Sep 13, 2009 | Freezers
Vacuumed my coils in my side by side, but the motor hasn't kicked back on. I don't know if i got the model number right...
which motor? compressor, condenser mtr next to the compressor or the mtr inside the frzr?
first chk to see if the fan mtr inside the frzr is running, if mtr is runnnig, then you have a problem w/compressor or relay loacted on compressor. alot of those compressor are locking up for no reason and maytag has a RECALL notice on their refrigs. contact maytag to see if your model is effected.
Jul 16, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Refridgerator and freezer wont get cold
sounds like a bad compressor, or at least the start device plugging in to the compressor has gone bad,
Mar 15, 2009 | Frigidaire FRT21H8 Top Freezer...
Cooling fan wont work
The water temp sensor is located near the thermostat housing. This sensor is what tells the ECM to turn the fan on/off. The water temp sending unit is located near the same area. You know you have the correct sensor is because the water temp sensor has a 2 prong plug. The water temp sending unit only has 1 prong.
Sep 26, 2008 | 1998 Chevrolet Cavalier
Aquacal HeatWave Logo
66 people viewed this question
Top Aquacal Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquacal Pool and Spa Expert? Answer questions, earn points and help others
