Hp color laserjet 5550 error code 13.20.00 top cover jam,what is the solution to that
SOURCE: 59 C0 error on hp color laserjet 5550
59.C0error on hp color laserjet 5550 dtn
can you please suggest a solution for the above error on my printer urgenty
Posted on Mar 29, 2009
SOURCE: Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Posted on Aug 10, 2009
Testimonial: "Good answers - unfortunately still no closer to solving the problem."
  • 138 Answers
SOURCE: hp 5550 laserjet paper jam
Thhis error is usually due to a dirty photcell (sensor) in the tray 2 paper feed assembly or a broken sensor flag in the same assembly. Start be removing all cartridges and the transfer belt. Look in the bottom of the printer below the lowest cartridge slot for a removeable cover. That's the area your problem is probably in. I have incuded a link to a free PDF of complete service manual below. Good luck.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%205500-5550.pdf
Posted on Aug 03, 2008
SOURCE: hp color Laserjet 5550 59.C0 printer error message
hp_color_laserjet_5550_59_c0_printer
Posted on Feb 20, 2010
SOURCE: I have a 59.30 error code on a HP color laserjet
i have a 59.30 error code on a hp clj 5550
Posted on Mar 23, 2010
Error code 59.61 on hp color laserjet 5550
Book says that it is the cyan drum drive assembly that needs replacing. Part number RG5-7723-000CN.
DO NOT attempt to do it yourself. A tech needs to do it.
Feb 19, 2015 | HP LaserJet Office Equipment & Supplies
My printer hp color laserjet displays a printer error 57.07 i need to a process to clear the code
Try looking up that specific error code and it should tell you what you need to do.
Dec 28, 2014 | HP Color Laserjet 5550 5550n 5550dn...
Hp COLOR laserjet 5500
Power off the device. Remove the new fuser. Ensure there is no debris or paper through the paper path (blow some air through it.. Ensure all the flags are neither broken nor in the wrong position. Reinsert the new fuser, ensure the covers are properly in place then power on.
Jul 09, 2014 | HewlettPackard HP Color LaserJet 5500n...
Have a 59.30 error code on a hp clj 5550
My printer displays a 51.23 error, what to do? hp laserjet pro cm 1415fn color mfp
Oct 09, 2013 | HP Color LaserJet 5550hdn Printer
Sir, i have a hp clj 5550 printer acept cyan all other color printing
Check the black clip on cover on top of the paper pick up assembly under the cyan cartridge.
If it is not fitted correctly cyan will not print and no error message will be displayed.
Aug 17, 2011 | HP LaserJet 5550 Printer
I have a error code 59.30 on HP laserjet 5550
here is the solution for your hp color laser jet 5550 printer
fbd1ddf.jpgThis will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 23, 2010 | HP Color LaserJet 5550hdn Printer
the printer is sensing that one of the motors are not turning.remove the cover from the left side .you will find the main drive motor,next to the motor you will find a sensor clean this sensor with some electronic board cleaner .be sure that the sensor it dry before turning the printer on.
Dec 17, 2009 | HP LaserJet 5550 Printer
How do you resolve 59.30 error code on HP color laserjet 5550
finally i solve this problem hp colorlaserjet 5550 error 59.30 same with an error 59.40 ERROR this is occurred with the fuser motor during startup or not rotating. take the left cover off and replace the motor. hope this will help.
Jun 09, 2009 | HP LaserJet 5550 Printer
497 people viewed this question
jasbo
jasbo
