Question about Ricoh Aficio SG 3110SFNw Color Inkjet Multifunction Printer
Turn on printer alert light remains lit - Ricoh Aficio SG 3110SFNw Color Inkjet Multifunction Printer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
Hello I saw the break alert light lit on my
Usually when th fluid level low light comes on, it is because the fluid is ging to the front calipers to fill the pistons that push the brake pads against the rotors. This is because the pads are worn down and probably need replacing.
As for the 3 beeps, it is not related to the brakes.
if it is 5 beeps, it is the air bag or pretensioner.
When the ignition is cycled (turned off and then on), the air bag indicator will remain lit for six seconds and then go out. If an SRS fault exists, the air bag indicator will then flash the two-digit LFC. The air bag indicator will flash the LFC five times, then it will remain illuminated for the rest of the key cycle. The RCM will also communicate the current and historical DTCs through the data link connector (DLC), using the scan tool. If the air bag indicator does not function, and the system detects a fault condition, the RCM will signal the GEM to activate an audible chime. The chime is a series of five sets of five tone bursts. If the chime is heard, the SRS and the air bag indicator require repair.
Mar 02, 2010 | 2002 Ford Ranger Regular Cab
All LED's are lit
Sometimes when you turn electronic equipment on, it kind of locks up and doesn't start as it should.
Try turning off the power (and remove the cable physically) and turn it on again, and see if that helps.
Aug 13, 2009 | Ricoh SP C220N Aficio Laser Printer
Indicator light remains lit even though it is a full cartridge
It seems there are "new" chips & "old" chips in these ink cartridges for the HP 1200 inkjet printer. I have a cartridge with a "new" chip in and it is working fine. The printer doesn't read the "old" chips. Something to watch for when using refilled ink cartridges.
Apr 17, 2009 | HP Office Equipment & Supplies
Amber light remains lit at all times
Did you try to replace the battery?
Nov 25, 2008 | HP iPAQ hw6915 Smartphone
Battery light alerts when car is driving
The thing that sucks about the Sebring, I have a 2001, is that if there is a problem and your car detects it 3 times, it will stay programmed in the onboard diagnostic, even if you have repaird it. The only way to have that little light go out, is for someone to reset the onboard diagnostic computer with the fancy machine code reader that only the shops seem to have. So, have it reset.
Jul 25, 2008 | 2001 Chrysler Sebring
Brother HL-2040 All LEDs stay lit and the printer no longer works
Turn it on and when all the LEDs light up, THEN press the Go button. One or more LEDs will stay lit and the others will be off. Look in the user manual (you can find it online at the Brothers site if you don't have one). There is a chart in the Troubleshooting section that will tell you what problem your particluar combination of "lit" buttons indicates. It may suggest fixes, or depending on the problem, tell you to see a repair person.
Nov 19, 2007 | Brother HL-2040 Laser Printer
Orange light blinking
Solution: Confirm the ink tank(s) are properly installed iP4300
Ensure that the ink tank is installed properly. Open the Top Cover, Paper Output Tray and Inner Cover, and then press on the 'PUSH' mark on the ink tank whose lamp is off until the ink tank clicks into place. Once the ink tank is installed properly its lamp will light red.
Ensure that all the orange tape has been peeled off as shown in (1). If a part of the orange tape remains as shown in (2), remove it completely.
(1) Correct (An L-shaped notch* appears on the ink tank.)
(2) Incorrect (Orange tape remains. Peel off the tape along the perforation.)
Nov 02, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Ricoh Aficio SG 3110SFNw Color Inkjet Multifunction Printer Logo
19 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
