Question about John Deere 6200 6300 6400 6500 7500 Water Pump (John Deere)
How do I bypass bcu on a 6400 johndeere to make pto operate
5 Suggested Answers
wadembly
  • 475 Answers
SOURCE: My Johndeere 2510 pto will engage. But you have to
its actually the clutch not disengaging enough for pto to engage or the teath are worn down on pto shaft
Posted on Jun 05, 2009
nova2nv
  • 197 Answers
SOURCE: PTO Tension JD 155C
Look between top of deck and bottom of machine for a rod coming from the rear topside of deck and going up to bottom of machine.Where it connects to machine there is a small pin you must pull to disconnect it.Once done loosen locknut and turn collar in,away from nut,3 or 4 turns to give PTO lever more pull.Tighten locknut,put rod/collar up and over crossbar and into hole it came out of,install pin.You may need to move PTO lever as if you were going to engage blades to help collar line up with hole.
Posted on Jan 10, 2010
BAMOUT
  • 2478 Answers
SOURCE: johndeere 6400 will not start in cold is there 1 preheat plug does this need replacing can they wear out
Its probaby burn out. Remove and test it. With a ohm-meter , set on ohm's. One lead on top and other on the bottom. On a wood surface or etc. If reads something its good. If reads ol yet its no good.
Posted on Feb 05, 2012
  • 512 Answers
SOURCE: clutch for johndeere 870
That is normal for a live pto. If your tractor has a two stage clutch you should be able to stop the PTO with clutch all the way in (as in push the pedal all the way down). It should be transmission independant, meaning it will work even though the transmission is not turning AND if you are running something that has a lot of inertia, it won't push you around by driving the rear wheels even though you have the clutch in.
Posted on Aug 25, 2012
How to replace fan belt on johndeere 6400
look at the pulleys the belt runs over and you will see one that is moveable. you will figure it out from there.
Dec 17, 2014 | Cars & Trucks
Wheelhorse 314 engines dies when pto is engaged
I am assuming you have a manual PTO clutch since you did not mention a PTO switch. The starting circuit generally is a series of switches wired in line (series) with each other. You have bypassed the seat but there is usually a switch for neutral, PTO, oil level, and clutch. You will need to trace the wires from one to the other to find the problem. If the seat has a double switch (3 or 4 wires) it is wired through the PTO switch which may be a double switch to short out the ignition so that part of the circuit should stay open to operate. If the oil level is ok and the oil has been changed as recommended you may better consult a Wheelhorse service person. Bypassing the switches is for testing only! I DO NOT RECOMEND LEAVING ANY SAFETY SWITCH BYPASSED. Any defective or out of adjustment switch should be replaced or corrected.
May 05, 2013 | Garden
Clutch for johndeere 870
Aug 25, 2012 | John Deere 760 790 850 870 Flail Spreader...
Johndeere 6400 will not start in cold is there 1 preheat plug does this need replacing can they wear out
Feb 04, 2012 | John Deere 6300,6300l,6400,6400l Tractor...
Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
May 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
PTO Tension JD 155C
Jan 09, 2010 | John Deere 48 in. EZ Trak Power Flow...
JD 6400 tractor, PTO light flashes when engaged but PTO does not work.
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Aug 30, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Home wireless network
A wireless router of course :-)
Az.
Sep 17, 2008 | Dell Inspiron 6400 Notebook
John Deere 6200 6300 6400 6500 7500 Water Pump (John Deere) Logo
51 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
