Question about Moultrie Feeders D55irxt Game Spy Camera
My D-55IRxt reads the mode then "CARD LOCKED" regardless of the card or position of the lock on the card. Says it is "TAKING" but nothing loads onto card
t00nz
  • 4738 Answers
SOURCE: Camera says SD Card is locked but card is open;
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Posted on Jul 11, 2009
  • 3 Answers
SOURCE: camera screen said SD card is locked when I installed an SD card
#1) On my camera if there was a picture that got stored in the internal memory it would not reconize the sd card nor store the pictures on the sd card. I would have to take the sd card out and delete the pictures in the internal memory and then reinsert the sd card.
#2) Some how or other the files that were on the sd card would get scrambled on the sd card when I would try to erase them. I would have to reformat the sd card back to a "fat" format before it would work again.
Posted on Jul 28, 2009
  • 296 Answers
SOURCE: moultrie DGW-100 won't read sd card
check small switch on side of SD card; should be pushed toward contacts.Using the USB cable provided with cam, PC SHOULD RECOGNIZE DEVICE...might have to go thru windows explorer to find it, then use windows media player, or other, to open.
You are running 98 or later, right?
Posted on Feb 17, 2010
t00nz
  • 4738 Answers
SOURCE: screen says card locked and
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Jun 23, 2011
SOURCE: SD card Locked
I have the same issue . . . tried new card, older card, 4 different cards, turned off camera, took out battery. I'm bummed.
Posted on Oct 16, 2011
Samsung es60 card locked solution
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 22, 2014 | Samsung ES60 Digital Camera
Trail Card Lock
May 12, 2013 | Moultrie Game Spy D-55IRxt Game Camera
Moultrie D-55irxt says sd card locked on
Dec 03, 2012 | Moultrie MFH-DGS-200 Digital Camera
Why does my camra say trail card lock on it and willnot take pictyres
Sep 27, 2012 | Moultrie D-55IRXT Game Camera
Card locked
If it is an SD card there is a little slider on the side that needs to be pushed into the open position.
Otherwise while loading it last time the lock button on your computer was pushed.
If you load your SD card into the computer them right click it. Go to properties and you can sometimes unlock it that way.
Also you can drag off all of your information onto the desktop and reformat the SD card and then put your info back onto it later.
Hope this helps
May 27, 2012 | Computers & Internet
Card Locked! Message on Samsung l313
Go into the setup menu and do a camera "reset".
Sep 07, 2009 | Samsung Digimax S500 Digital Camera
Camera says that my card is locked.
Well, you need to open up the camera to check the SD card slot. This tip may help How to fix a ‘card locked’ problem
Aug 23, 2009 | Canon PowerShot A560 Digital Camera
Memory Card Locked
:'( i'm in the same situation right now! :(((( I want my pictires back! i don't know what to do!
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Moultrie Feeders D55irxt Game Spy Camera Logo
Top Moultrie Photography Experts
pontelemon
pontelemon
Tony
Are you a Moultrie Photography Expert? Answer questions, earn points and help others
