Question about TORK SS720A 7 Day In Wall Digital Timer
Tork 701A in wall timer used to work but now does not, use it to turn on 2 flourescent lights
Noma TM701 user manual
That particular Noma timer number does not appear in my files, or on google search, except for your question.
Noma is old brand name used in past years by Intermatic, and then Woods, and mostly for generic off-brand timers sold at local store under Noma name for ez identification.
Copy following links to help identify your timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.htmlhttp://waterheatertimer.org/Woods-timers-and-manuals.htmlThere is a Tork 701A in-wall timer.http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Jul 11, 2012 | Hardware & Accessories
No display stop working. it controls a fan lite, the lite is on in a dimmed mode, no fan function.
Question posted under Tork SS720 timer.
I don't have repair for defective timer that worked before and stopped working.
If this is new timer, then add a comment and explain wiring in exact detail, and include what you mean by 'dimmed' mode.
Timers have 1 year limited warranty.
Timers are affected by line noise, and generally cannot be connected to a dimmer.
SS720A timer is robust 120Volt single-pole 7-day programmable timer, rated for 15Amp up to 1 HP.
The larger the amp load, the shorter the lifespan for electrical devices.
Last step troubleshoot for programmable timer is to reset timer and reprogram.
Reset timer by pushing in reset button for several seconds.
If functionality is not restored, then timer has gone bad.
Tork SS720 is identical to GE15071 timer sold at Home Depot.
Buy another timer, and return defect in new package.
http://waterheatertimer.org/pdf/SS720A-Tork-In-wall-manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Aug 19, 2011 | TORK SS720A 7 Day In Wall Digital Timer
I have an Intermatic E1020 timer and the manual control does not work consistently. The timer will turn the appliance on and off automatically but I cannot get the manual control to work. Please help!
If timer dial is rotating and keeping good time, then clock motor is good, and wiring is correct.
If timer turns the load on-off, then set of 156EB945A trippers are good.
http://waterheatertimer.org/pdf/Intermatic-e1020-english.pdf
I believe the manual control button reverses the program.
So if timer is ON, and manual is pushed, then timer turns OFF, and timer resumes programming at next tripper.
So the manual override is not an on-off switch.
All plug-in timers work same way, and most of the hardwire timers and in-wall timers.
The exception is the analog GE 15070, Woods 59017, Tork 701A, Intermatic E1120, Intermatic KM2 series. These timers have a true on-and-off switch that slides back and forth.
http://waterheatertimer.org/Programmable.html#15070
http://waterheatertimer.org/images/GE-15070-mechanical-timer.jpg
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 06, 2011 | Hardware & Accessories
My Tork 1101 24 hr timer has stopped working. I hear it running, but the clock will not turn. I have to turn it on and off manually for my pool pump. This happened 2 years ago, then the following year...
You might need $45 clock motor for for Tork 1101 120Volt.
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c10431
Open following link to identify timer and see replacement clock motor and trippers:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Intermatic crossover shows T101 timer replaces 120Volt Tork 1101.
Amazon sells new Intermatic timer for $45 with super shipping
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
Crossover wiring from Tork to Intermatic:
Black wire on Tork L and 1 connect to Intermatic terminal 1
White wires on Tork X connect to Intermatic terminal A
Black wire on Tork 2 connects to Intermatic terminal 2
http://waterheatertimer.org/How-to-wire-T104-Intermatuic-timer.html#T101
Upvote the help.
Jun 04, 2011 | Vacuums
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I need instructions on how to set the timers on my tork electric timer for my outdoor lights ,it is put into my switch inside
Here is link to Tork in-home timers showing digital 7-day programmable timer:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#SS700
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Nov 06, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How to set a tork timer?
Tork makes a page-full of timers.
Rotate dial until current time lines up with arrow, then set the pins as shown in photo below
1) If timer plugs into wall receptacle, it has pins around the dial.
2) If timer replaced a wall switch it also has pins around dial.
GE and Woods and Tork and Intermatic each make similar timers.
Pull and push the pins to set times.
The wall-switch type timer also has a switch >>> move switch to Timer
Up-vote if this information helped. Thanks for the feedback.
Oct 15, 2010 | TORK 401A 24 Hr Mechanical PlugIn Timer ...
I have a Tork 806A timer, but no instructions on how to set the on/off cycles.
Tork 806A: There are 6 outlets. Bottom two outlets are always on. Top four outlets controlled by timer all four outlets turn on and off at same time.
Load: Total load on all 6 plugs cannot exceed 1500 Watts, which is typical for 15A circuits. Indoor wall plugs are 15A. Don't add more load to timer than you would put on ordinary wall plug.
Set Time: Rotate dial clockwise to set time. On face of dial, Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} push tabs down to turn on loads, pull them up to turn off loads.
Reset: Timer has reset button in top left corner.
Jul 25, 2010 | TORK Digital Interval Timer Ssa100r-24
TORK SS720A 7 Day In Wall Digital Timer Logo
52 people viewed this question
Top TORK Hardware & Accessories Experts
 Kenneth
Kenneth
rgbypoet
Andrew Taylor
Andrew Taylor
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
