Question about Fujitsu Siemens MYRICA P50-2 50 in. Plasma TV
Firmware Myrica - Fujitsu Siemens MYRICA P50-2 50 in. Plasma TV
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
Fujitsu Siemens plasma TV P50 - works ok - the problem is the remote control, always been a problem - bad signal ? it was nessesary to directed very exact towards the TV and not too far away/less than 3 m/...
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://schematicscom.blogspot.com/
http://homenol.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
May 13, 2017 | Fujitsu Siemens MYRICA P50-2 50 in. Plasma...
Hello. I have a Fujitsu Siemens TV Myrica PDP-TVP PQ 42-1, and it is 5 years old. No problem until today. First did the colours slowly change. After re-starting the colours were ok for a short while,...
Sounds like to me you either have a video processing problem or you have a powersupply issue. The only way to tell is to open set up and check the powersupply voltages and then go from there.
Let me know if you are willing to open that baby up and then we can check for correct power supply
voltages... Talk to you later. HDTV GURU JAY
Mar 16, 2011 | Fujitsu Siemens Televison & Video
We got a Myrica PQ42-1 that takes the fuse in our house all the time. After 2-3 times it turns on. Is this normal??
I have the same problem. Returned the TV for warranty repair and got it back still with the same problem. "Change your fuses to 16A slow" was the message from FSC service shop. (16A=3500Watts!)
I have mounted a 10A fuse directly 'between the TV and the 230V outlet so the (house) fuse does not drop.
Now my ******* TV went all black, probably the backlight.
Jul 08, 2010 | Fujitsu Siemens MYRICA P50-2 50 in. Plasma...
Black screen on my Fujitsu Siemens Computers Myrica television
sound no picture does it flash when first powered on ? its the invertor board it controls all the lamps
that light the screen/shine torch into screen you
will see picture/needs repaired google{ohm supplies uk}
Apr 18, 2010 | Televison & Video
I HAVE PLASMA TV MYRICA P50-2.
The link below is where you can get the information about how to buy Fujitsu television parts. I have no idea if they will sell to non contracted servicers. These sets are serviced mainly by board swapping. You can eaily buy boards that you think are defective, and they are not the fault. This is the gamble you will be taking when servicing these sets yourself.
http://www.fujitsu-general.com/global/contact/pdp.html
Jerry G.
Jan 31, 2009 | Fujitsu Plasmavision PDS-5001 50 in....
Fujitsu Siemens MYRICA P50-2 50 in. Plasma TV Logo
87 people viewed this question
Top Fujitsu Siemens Televison & Video Experts
kj henriksen
kj henriksen
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fujitsu Siemens Televison and Video Expert? Answer questions, earn points and help others
