Question about Refrigerators
Samsung side-by-side refrig is not staying cold
I have a Samsung side-by-side refrigerator that is not staying cold. To bring the temperature down I have to unplug my unit for 10 minutes and then plug back in a push the power cool button. But after a few hours it goes back up to 65 degrees.
  • Megamom Sep 28, 2007
    My Samsung refrigerator model number is RS257BARB.
  • Anonymous Jul 15, 2008
    Refrigerator cycles between 38 and 61 degrees. This is a known issue with these refrigerators, the part should be recalled/replaced before the issue causes all of us to lose hundreds of dollars worth of food. The tech said that the defrost mechanism is broken. That helps a lot.
  • 473 Answers
Look for signs of frost build up on back freezer panel. If there is build up then it has a defrost problem. I haven't had much experience with samsung but I beleive it has a fuse in the defrost circuit on the evaporator and that may be the defrost problem.
Posted on Oct 06, 2007
I had the same problem on the same model and the problem was fixed when the repairman replaced both defrost sensors. he said the ellow tabbed one from samsung was faulty and samsung was issuing out the blck tabbed ones. hope this helps
Posted on Jul 24, 2008
Take everything out of the fridge, unscrew the back panel inside and reveal the cooling grid. If there is frost there, you need to replace the fuse quick before it damages the mother board, freezes your water line, freezes your water reservoir (plastic which will then crack and leak). But you're already seeing high temps, so you're with me - not under warranty and not cooling.
Posted on Jun 12, 2008
  • tauruscalugu Jan 29, 2011
    I purchased a complete Repair Manual off e b a y and was able to trouble shoot my freezer problem down to the condenser heater relay on the PCB, i was able to go to digikey and purchase the relay and not i am up and running again and has been for 5 months now.
    Model RS2556SH
SOURCE:
MY GE MONO SIDE BY SIDE REFRIG,MDL ZISS480DRSS IS FREEZING THE REFRIG SECTION.THE TEMP READ SAYS IT IS NEARLY 80!I THINK IT MAY BE REACTING TO THE TEMPERATURE DISPLAY AND TRYS TO COOL IT DOWN.HELP!
Here are possible parts that could cause the problem
GE Refrigerator Freezing Food but the most common is the diffuser/damper that got stuck open and cold air from freezer continously coming in to the fresh food side.
Nov 22, 2017 | GE Refrigerators
Kenmore Refrig Model 596.50699000, not getting cold as should. Frost forming on top row of coils only?????
Clean the condenser. Probably below refrig. Reset all settings to mid point and check to see if you have a restricted drain tube.
Jun 17, 2012 | Kenmore Side by Side Refrigerator
GE pss25ngnacc____refrigrato is to cold can't control tem
start by putting freezer control on half way on the numers. lets say it goes to ten set on five, do the same on refrig side . let run for 24 hrs. so it can stabalize. if it is ok in freezer and things are frozen and too cold in fridge side turn the refrig side to one smaller number. check again in 24 hrs. don't keep opening the door so that it can stabalize. if that doesnt work then it could be the cold control not senseing the temp of the refrig.
May 26, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Can't change temperature
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem
May 24, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerator cold control doesn't work; temperature stays at or below freezing. Freezer control OK.
check the damper door between the refrige and freezer compartments,its behind a plastic cover,if its iced up in the fully open condition it will allow too much cold air into the refrige,if this is the case defrost it with a hair dryer and recheck operation,otherwise the temp control in the refrige is bad
Mar 18, 2010 | Refrigerators
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge gets very cold even when I turned down the temp to #1
You have air dampers in this fridge.
Adjust them to a warmer setting.
Look along the left wall down low beside the vegetable bins.
If this does not correct the problem you have electronic temp sensors that have gone bad.
A technician will be needed to determine that.
Keep your fingers crossed that the damper is too open.
Any adjustment will take 24 hours to be noticeable.
Mar 12, 2009 | GE GSS25LGM Side by Side Refrigerator
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
1,217 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
