Question about Toshiba gigabeat® X60 (60 GB) MP3 Player (MEGX60K)
Gigabeat megx60 could not open - Toshiba gigabeat® X60 (60 GB) MP3 Player (MEGX60K)
Toshiba Gigabeat Touch Controls broken - need to transfer music to iPod
remove front cover on Gigabeat F40, remove battery. on back of battery a spacers remove those and replace with thinner spacers. I used hi quality insulation tape three layers of and stick back onto battery. Install battery again and it will have fixed the problem. Did it with mine
Jun 15, 2012 | Toshiba Gigabeat F40 40 GB MP3 Player
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
Could I please have more instructions on how to restore firmware data as I am still getting same results. "NO SYSTEM FOUND ON HDD" 00200060
Just install your software that came with your Gigabeat. After installation please run the following program. Start/Programs/Toshiba Gigabeat Room/Formatting Utility for Gigabeat. This will place all the files back in the hard drive. Please do not format this unit from My computer to the drive letter. You end up deleting the system and boot files. if that does not help try this in your software you right click on your gigabeat room and open it up and find gbsytem folder drag and drop into your gigabeat on your my computer screen. and then check out.try it couple of times.many times this does work for first time directly. -------- you can also try contacting topshiba service center click the link directly http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp ---------- try downloading the firmware again and installing it in your device click this link directly for firmware http://www.megaupload.com/?d=MO4S7T6I ----- This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
Oct 22, 2009 | Toshiba Gigabeat MEG-F20K (20 GB) MP3...
Gigabeat room fails to recognize my Gigabeat
It seems to be a permissions thing. When you launch Gigabeat Room, right click and choose "Run as Administrator". The Gigabeat button is then activated in the room interface.
Oct 30, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Computer does not recognize Gigabeat Device
Check the manufacturers website for specific Vista drivers.
Mar 08, 2008 | Philips GoGear HDD075/17 MP3 Player
Gigabeat Room
I've got the install CD that has gigabeat room 2.02 - US version. if someone wants it - email me the request and I'll email a zip of the whole CD. it's only 29 MB (kelly . piper . cherokee at gmail . com) remove spaces...
Feb 16, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat 40GB screen frozen
well, it would be really easy to take off the battery. The battery is simply plugued with a little 3-pin wire, u just pull on it and put it back in. Now to open that gigabeat, its pretty easy. I even got some images for u. Go at this website (its for the F10 and u have the F40, but its the same thing): http://www.angelfire.com/bug2/gigabeat/
Mar 24, 2007 | Toshiba Gigabeat F41 (40 GB) MP3 Player
Toshiba Gigabeat (60GB): How to put movies on?
Yes you can put movies on Gigabeat but it's time consuming and takes 3 programs to do it. We use DVDfab Platinum,3GP_Converter and Windows Media Player. If someone out there has a simpler way please post. 1st. Rip your movie to your hard drive and remember where you put it. (We've found using DVDFab Platinum it's easiest since we have PSP, Gigabeat & I-Pod and it offers a conversion program for all plus burning our home movies is a cinch.) 2nd. Open your 2nd conversion program (we use 3GP_Converter) and drop your burned movie files into it. We love the 3GP cause you just drag & drop. I don't know why the Gigabeat needs an extra conversion but it does, my PSP is easier to get movies onto. =( 3rd. Open your now fully converted movie with Windows Media Player. And you know the rest: just sync. While I love my Gigabeat it's pretty ridiculous to have to do all this to watch one little movie because it doesn't always work. However, unlike my PSP I can put a whole bunch of movies & pics & music on my gigabeat without running out of room! My husband is a computer geek and has tried several programs and this is the easiest way he's found to rip movie, yikes!
Mar 10, 2007 | Toshiba Gigabeat MEG-F60S (60 GB) MP3...
Toshiba gigabeat® X60 (60 GB) MP3 Player (MEGX60K) Logo
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Electro Med Services...
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
