Landis gyr Chronogyr Rev 10
Hi. We have the above hydronic heater. I have followed the instructions but cannot get the system working. What else can I do? Thanks. Joe
5 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: Electric Hydronic Baseboard Heater Under Electrical Recepticle
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Regards,
Rick
Posted on Dec 02, 2008
SRF518
  • 232 Answers
SOURCE: Marley Hydronic baseboard heater not turning on
on the one that don't work use a clamp around ammeter and see if you are drawing current. no current, the heater element is shot!
Posted on Oct 23, 2009
  • 10865 Answers
SOURCE: I'm replacing a non-hydronic electric baseboard
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Posted on Jan 06, 2010
Testimonial: "Excellent Reponse"
SOURCE: ideal classic boiler no heating only hot water
Hi I have some boiler problems, I`m the proud owner of an Ideal classic SE12ff. The controls are that of Sunvic select Xl.
The problem is I can only get the hot water to work when the heating is on, I neglected this over the winter but now the summer is apparently fast approaching I am desperatley trying to get this solved. A plumber has done some fault finding with no prevail, have you any suggestions?
Posted on Apr 23, 2010
Landis gyr meter manual
computer software ?
PDF]User Manual - Landis+Gyrwww.landisgyr.eu/product/map/?download=78003
Apr 29, 2017 | Cars & Trucks
I have a gas meter and pay as I go card but the machine will not accept my card , what do I do "?"
Call the card companie and see if you have funds on the card. Sometimes I think I do and then I didn't realize the fees ate it up. Or they could have shut off your card.
Jan 04, 2015 | Siemens Landis & Gyr 536 765
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
How do i reset a landis prepaid meter
You do realise that the itme you are asking about is not a computer motherboard, don't you? It is a heating system controller.
Apr 21, 2013 | Siemens Landis & Gyr 536 765
How do I wire 2 Hydronic 1500W 240V heaters together?
Please follow the attached wiring diagram on page four on the web link below.
Hope this helped you....Jim...Please leave a positive comment if it helps you with your project.
http://www.thermalinc.com/comfort/PDFs/LF_instructions.pdf
Feb 14, 2011 | Fahrenheat Electric Hydronic Baseboard...
Ideal classic boiler no heating only hot water when heating is switched to on there is no sound from system but there is when water switched on. the rads upstairs were warming up but not downstairs now...
Hi it sounds like the pump is not working or diverter valve not working check to see if pump is working on ch mode as well as valve , pump could be stuck ,
Apr 12, 2010 | Heating & Cooling
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Regards, Joe
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
IS A HYDRONIC ELECTRIC BASEBOARD MORE EFFICENT THEN THE STANDARD ELECTRIC BASEBOARD HEATER
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Do the Fahrenheat Hydronic Baseboard heaters work well?
No i would not recomend this model ! if you can stay away from baseboard heat alltogether it is an energy waster!,somthing that moves the air would be a much better choise
Dec 10, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Heating & Cooling Logo
371 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
