Question about Hoover F5881-900 Vacuum
Brushes turning slow on Hoover F5881-900 steam vac
Brushes are barely turning and only when vacuum is moving. What powers the brushes and is there an easy fix?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
There is a part inside called the turbine which needs to be replaced or cleaned. Also clean the brushes.
Posted on Feb 10, 2008
Brushes stopped turning
check the drive peg that turn the brushes it may have broke and needs replaceing this link is for the manual it will show you how to get the brushes off.
http://hoover.com/file/670/
Aug 11, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
SteamVac F5914-900 SpinScrub Upright Vacuum: Is it ok to use the hoover steamvac on tile floors...
Yes, your Steam VAc will work on tile floors. You'll want to remove the rotating brushes and install the Bare Floor Tool attachment - Hoover part number 48417003
May 16, 2010 | Hoover SteamVac F5914-900 SpinScrub...
New Hoover Steam Vac's brushes do not spin
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Turbine Brush Gear Part # 43191008
F5914 Parts Link
http://www.usavacuum.com/Hoover-F5903-F5904-F5905-F5910-F5912-F5914-F5915-s/138.htm
Feb 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Hoover F7458900 steam vac brushes won't turn
No, there is a turbine that turns the brushes. You can take the top cover off to get to it, open it up and clean it out and then try it again. If that doesn't work, then replace it, or just replace it to begin with.
Jun 08, 2008 | Vacuums
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Brushes do not rotate on Hoover steam-vac upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564960
posted by marshad on May 02, 2008
brushes do not rotate on Hoover steam-vac upright
This also happened to my own Hoover Steam Vac and there was a broken part that connected to the brush assm that I had to replace, it has been a while but once they replaced the part everything worked just fine and it was not that expensive and I am still using the vacuum still to date and it is working just fine. I believe it was something like the switch for the brushes on/off switch or the part was part of the handle assm. Check you owner’s manual for the exploded view on the vacuum or also check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Belt on steam vac v2
The V2 doesn't use a belt, it uses a turbine to drive the brush block, If brushes are not turning, either the shaft on the brush block broke off, or the turbine is bad and will have to be replaced.
Dec 23, 2007 | Hoover F5906-900 Upright Steam Vacuum
Hoover F5881-900 Vacuum Logo
301 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
