Question about Datacard SP35 Plus Printer
Trying to install new ribbon..keep getting message that there is no ribbon or wrong ribbon. Ribbon is correct
5 Suggested Answers
  • 36 Answers
SOURCE: Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
Posted on Mar 19, 2010
  • 11 Answers
SOURCE: data card sp35 plus ribbon break
Three things to try,
1. Try actually flipping the cards over, on side may have a burr that is cutting the ribbon.
2. Try changing the position of print on the card. Most manufactors call this EC
3. Try calibrating the ribbon sensor from with in the driver or the datcard utility that is on the bottom right of you windows desktop
Posted on Jun 03, 2010
  • 1116 Answers
SOURCE: Good afternoon, I am
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Posted on Jun 20, 2011
  • 36 Answers
SOURCE: Datacard CP40 Plus printer with
Sounds like you are using an incompatible ribbon. Please post the configuration for the printer which is on the left side under the cover (white sticker) and your ribbon part number. If you are sure both are correct you may have a defective print ribbon or your printer will need service.
Contact TulsaBiz.net for more info
Posted on Aug 15, 2011
Ink-ribbon error
The problem you are having is the unit uses various cartridges that the ink spools must match. You must have the correct cartridge with the ribbon you are using or you will get that error message. There are three types available from the manufacturer. P+ for the Photo ribbon, The Color Insignia for the Color Ribbon and the Versamax brand ribbon although i don't recall what the symbol is on that one. If you are trying to load a spool of Photo ribbon on a color spool that message occurs. Hope this explains everything.
Aug 19, 2013 | Teac P-55 Thermal Printer
Bought a DTC520 and replaced Printer ribbon and now message reads " No Printer Ribbon Installed" Used Part # 86031 DTC500-YMCKO I powered down machine and started again, still NO Ribbon...
You have to check which ribbons are loaded.
Depending on that you have to select the appropriate mode in the driver else it'll keep giving this message.
Y = yellow
M = magenta
C = cyan
K = black
O = overlay
May be you don't have overlay loaded
Aug 15, 2011 | Fargo DTC515 Thermal Printer
I have a gx6750 correcting typewriter. The problem is, the correcting part of it does not work. I am wondering if the correctable ribbon indicates "correctable" on the cartridge or not. I am...
A correctable ribbon should be correctable. Is the ribbon being lifted up high enough to correct?
Is there any letters on the correction ribbon and is the ribbon installed correctly? Old ribbons lose their tackiness over time, try advancing the ribbon by hand to get to fresher ribbon.
Jul 08, 2011 | Brother Office Equipment & Supplies
I just installed a new ribbon on my olympia deluxe and the ribbon keeps getting loose. Could that be because I installed the ribbon wrong? What could be the problem?
You probanly installed it wrong. Most T/W's spooled ribbons wind to the outside of the spool, however there were a few that wind to the inside. Withe the ribbon off type & watch the spool mech. install the ribbon so that it will wind onto the spool.
DickyO
Nov 09, 2010 | Olympia Office Equipment & Supplies
DTC550 Fargo printer it says out of ribbon with new installed
Check to see if the RFID (green ring) from the old ribbon has come off and is stuck near the reader (located behind the green stem). I've seen that happen. I've also see some bad RFID rings. If that happens they should have a warranty from Fargo.
onlineidtech
Mar 19, 2010 | Fargo DTC550 Thermal Card Printer
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Brothers SX400 - cannot get ribbon threaded so key strikes it
If you bought the correct ribbon for a start, then you do not need to rewind it. It should come already wound round its pulleys, and should not fail due to slippage. there should be supports in the mechanism to keep the ribbon in place.
Assuming you have the correct ribbon (that is the fabric is in its right position), and the cassette casing design is correct, the cassette should sit squarely and correctly to enable your printhead to strike the ribbon when you press your keys.
So, the reason why the casing is sitting about 1/4 inch above the guide may well be because of a wrong casing design. Carefully compare the design of the ribbon cartridge that you have with that of an OEM. YOU MAY FIND a lug or protrusion. If this is the case, I suggest you get a new compatible ribbon cartridge with a good design from a reliable source. www.inkribbonpaper.co.uk is one such source.
Aug 31, 2009 | Brother SX-4000 Typewriter
"check ribbon " error is comming on my tally 2280+ serialprinter
The ribbon I had installed (code 061627) which says it is the correct one is in fact not. the drive pin on the printer slips while feeding the ribbon.
I have fitted a (code 062471) and now it is printing fine again.
a google search reports both these codes as compatible but they are quite clearly, not.
Jan 24, 2009 | TallyGenicom 2280 Matrix Printer
Datacard SP35 Plus Printer Logo
Top Datacard Office Equipment & Supplies Experts
Safe-Card ID...
Don  Farrell
Don Farrell
Are you a Datacard Office Equipment and Supply Expert? Answer questions, earn points and help others
