Question about Fuji FinePix S2 Pro Digital Camera
My finepix s2 can take a picture, but can see nothing.
    New Friend:
  • 22 Answers
Check your memory card for errors
Posted on Oct 22, 2013
Fuji FinePix S2 Pro New 4 Gb disk in cam prompts msg ''Card not initialzied.'' Have tried many things. None work. Help.
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Jun 25, 2010 | Fuji FinePix S2 Pro Digital Camera
Fuji Finepix S2 Pro
Ensure the batteries are the correct kind and chemical makeup (yes it does make a difference!)
try using lithium or alkaline as oppose to standard =]
Otherwise there may be an issue with the camera itself, check for warranty? if it isnt under warranty, document the error message/number, consult the manual AND the support site for the manufacturer.
good luck! =]
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 - image records in black
Could be CCD Failure ... known as ' Black Screen of Death'.
Have CCD cleaned at a reputable camera (not chain) shop and they'll test it.
Fuji were replacing units suffering this problem at one stage.
May 05, 2008 | Fuji FinePix S2 Pro Digital Camera
FinePix S2 Pro
replace the cr123 batteries. If one of them is down on voltage you will experience exactly the symptoms you describe.
Jan 15, 2008 | Fuji FinePix S2 Pro Digital Camera
Picture is black
take the lens cover off ? :)
Oct 27, 2007 | Fuji FinePix S2 Pro Digital Camera
FUJI S2 PRO
Maybe your card is already def.
Aug 08, 2007 | Fuji FinePix S2 Pro Digital Camera
Error
Before the heart attack, check your lens. I believe its the D series lenses that need to be set to all the way open. I get this "err" alot, and then look down to see that Ive rotated the appature.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
No picture
My S2 is on its second out of warranty CCD, and Fuji replaced both for free, the first was due to the same dead CCD as many has had, the second was due to the CCD being defective to the point of being off center and producing photos that had a very distinct leaning to the right, Fuji did not charge me for either CCD's, and if the tech said otherwise, if I where you, I would call them back and say you belong to many on line forums, and have read that Fuji is replacing them at no charge, its possible that the rep you talked to is unaware of this! That is another point, make sure you talk to an actual camera tech, and not just a rep, the rep will probably give you the run around.
Fuji FinePix S2 Pro Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
