Question about HP Officejet 4215v All-in-One Printer
SCANNER FAILURE WHENEVER I TRY TO FAX OR COPY A DOCUMENT MY HP OFFICEJET 4215V ALL-IN-ONE GIVES A "SCANNER FAILURE, RECYCLE POWER AND TRY AGAIN" SHOULD I REINSTALL? WHAT IS CAUSING THIS?
    President:
  • HP Master
  • 2,022 Answers
First you try with changing the usb cable and see. bye
Posted on Sep 28, 2007
SOURCE:
How do I use the scanner to my hp officejet 4215v all-in-one???? or how can I scan a document????
JUST put the document needed to be scaned face down as you send a fax and then go to the start program and will find the scan image from a sccaner or can go to control pannel and choose sccaner and imaging devices double click to open and choose your scanner and can say get images from sccaner and it will be all done
good luck
Dec 05, 2010 | HP Officejet 4215v All-in-One Printer
I want to know how i can use my copy machine to a fax so i can use it for incoming or outgoing?
Install software
Make sure all cables plugged: phone cable, USB cable to computer
Send fax from computer:
- print your document to printer HP .... FAX
Send "traditional" fax:
- put your document into scanner input
- type phone number on HP Officejet keyboard
- push button "Send"
If your HP Officejet if connected to phone line, it reseiving faxes automatically.
Hope this helps
Nov 12, 2010 | HP Officejet 4215v All-in-One Printer
My printer gives me a message of scanner failure. Unable to scan, copy or fax. What should i do?
I think you must delete the drive and reinstall anew drive for it
I hope it can help .
Oct 04, 2010 | HP OfficeJet J4580 All-In-One InkJet...
Need to know how to receive a fax on my hp printer
Hi there;
As you are looking for the fax with your HP Officejet 4215v i would request you to go threw these two website which will help you to setup the fax as well will help you to get the fax on your printer as you have not mention how you are trying to connect your printer to get the fax
Using the Product with a Telephone Answering Machine:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu04072&tmp_task=solveCategory&lc=en&dlc=en&cc=in&lang=en&product=351112
How to connect your HP Fax to an Analog line with other analog devices:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00293279&tmp_task=solveCategory&lc=en&dlc=en&cc=in&lang=en&product=351112
Oct 19, 2009 | HP Officejet 4215v All-in-One Printer
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 08, 2009 | Office Equipment & Supplies
HP OfficeJet 7110xi
finally you can try a reset on the macj\hine using the # and the number 6 buttons(holding them down and then plugging in the power cord at the back of the machine).If it still gives the same error..try the same with the # and 9...same problem comes up....service the printer
Jun 24, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Scanner FailureTurn power off then on again Message Window pops up continuously
Below is the document that i want you to follow.
CLICK HERE ===>> DOCUMENT
Pleae let me know the result after performing the steps.
thank you so much.
adonscott
Jun 26, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Apr 25, 2008 | HP OfficeJet k60xi InkJet Printer
HP Officejet 4215v All-in-One Printer Logo
149 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
