posted by tody on Sep 28, 2007
TV TURN OFF BY ITSELF TRY TO TURN TI BACK ON WITH REMOTE BUT FAIL
1 Other User Has The Same Problem
Comment by texasboy08, posted on Dec 02, 2007
tv will last for 20 minutes then when it gets warm it turns off and when you turn it back on it shuts off by itself after 10 seconds.
Best Solution
posted on Oct 07, 2007
If this happens after it has been on for 5 to 20 minutes and can be turned back on after 10 minutes or so, there is a transistor labelled Q601 whose collector lead has been formed and is too short to project through the solder on the circuit board. When it gets hot it pulls away from the solder.
If this happens right away or after only a few seconds, there is a 3 terminal voltage regulator with 7805 in its part number that may have a low output voltage rather than 5 volts.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Emerson EWL20S5 20 in. EDTV-Ready LCD
Email this problem
Email this problem
Can you Help with these Flat Panel Televisions problems?
Emerson EWL20S5 20 in. EDTV-Ready LCD...
EMERSON EWL20S5 20in
i cant get any sound no matter... Answer This...
audio problem
audio problem
I cam barely hear the sound... Answer This...
emerson tv
emerson tv
i have a emerson flat screen tv... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
