My brand new roper washing machine RTW4640YQ1 isnt agitating. It just kind of rocks the clothes
  • 274 Answers
SOURCE: Agitator-How do you get it off?
(Roper is actually made by Whirlpool) This is simpler than it sounds, just takes time and a few steps. Do you have a fabric softener dispenser that resides on top of the agitator? This dispenser simply snaps onto the top of the agitator. Some styles use a decorative cap. To remove the dispenser, simply grab it and firmly pull up. There is a cap that covers the bolt or nut that holds the agitator in place. To remove the agitator cap, insert a small flat-head screw driver into the seam between the agitator cap and the upper agitator (the part that moves). Use a twisting or prying action to pop the cap off of the agitator. Sometimes there is a little slot where you can insert the screwdriver. Look for it first. There maybe an internal debris cap under this: Inside the agitator you will see a cap with a raised handle. Simply reach into the agitator and twist the cap while pulling up. This will remove the cap and its o-ring. Removing the agitator: When looking into the agitator assembly, you will notice a single nut in the center of the agitator. Use a socket kit or nut driver to remove this bolt or nut from the agitator stud. Don't use plyers, it'll just mess up the nut. With the bolt removed you should be able to remove the agitator by simply pulling up. Twist back and forth CW & CCW when lifting. Some are a 2 piece design, so pulling up will actually remove either the whole agitator assembly or only half of it. If whole assy comes up and you may need to seperate the two for your new parts. Place the Lower Agitator on the floor and stand on the flat lip. Then Pull up to separate the Upper Agitator (mover) from the Lower Agitator. As far as your parts go I'm not sure where they go without seeing it myself. There is a spline or ratch assembly which causes the agitator to move back and forth. They are usually made of plastic and get worn or break. This might be what you are replacing. It's not clear as to what parts they gave you. Good Luck
Posted on Jul 17, 2007
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
  • 148 Answers
SOURCE: Roper washing machine- unbalanced spin - rocking agitator
I usually stand in front of the washer and take the plams of my hands and forcefully provide a force with the heel of my hands on the side front corners and the lip comes up
Another option is to pull the washer out and remove 2 clips (usually requires quarter inch nut driver to allow the top to come up
This should allow you to get the top off to see if a spring has broken or slipped off
GOOD LUCK!
Posted on Jan 04, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
FixinFax
  • 3085 Answers
SOURCE: agitator not moving like it should
Pull off the softener cup
remove the small cap
unscrew the bolt
remove top half of agitator
replace the plastic DOGS
Posted on Feb 07, 2010
Roper wwshing machine model rtw4640yq1 during spin cycle bounces across the floor
Sounds like your load of clothes are not balanced. Like more on one side than the other.
Oct 17, 2016 | Roper Washing Machines
Model RTW4640YQ1. How can I disassemble?
Go to www.repairclinic.com and enter RTW4640YQ1. You will be presented with a list of common replacement parts and may be able to view a general video that shows disassembly of a Roper machine.
Apr 23, 2016 | Roper Washing Machines
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Roper Agitator Noise
thanks for that ,i'm glad i could help.would you help me please with my ratings and i thank you for that. God bless ,tom
Jan 26, 2009 | Roper RAS6233KQ Top Load Washer
Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Jan 22, 2009 | Roper Washing Machines
Agitator Noise of Roper RTW4305VQ
yes this noise is normal.its the dog ears ratcheting in the agitator
Jan 19, 2009 | Roper RAS8244KQ Top Load Washer
Rooper washing machine- unbalanced spin - rocking agitator
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jan 03, 2009 | Roper RAS6233KQ Top Load Washer
Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Jan 26, 2008 | Washing Machines
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
